Results 11 to 19 of 19
December 29th, 2003 10:15 PM #11Originally posted by ARB
What i did to my isuzu since i cant afford to buy OME leafs is invert the leaf it improved the ride but still not as good as OME leaf pack.
pwede rin kaya mag invert sa crosswind?
December 29th, 2003 10:38 PM #12
sir ARB, so ibig sabihin reversed na? Tama ka po. 5 leaves, 3 in contact 2 not in contact...so bale wala nang chance to get improved ride by reversing springs?
December 30th, 2003 12:07 AM #13
note - well the only solution is to change your shocks if you are not yet satisfied with the ones you have. or put a 50kilo sand bag to put a little load a bit to stop it from jumping when hitting holes. the strada is the best interms of ride sa all new pick-ups.
x-wind- as i have noticed the crosswind has a different setup than the pick-up, you dont have the shortest leaf, i think you have four long ones. please correct me if im wrong, the only thing that you can do is that you have to do something sa bracket yata that is holding the parking brake lines to invert the last leaf. if you can post a piture of the leaf pack maybe we can figure out something.
December 30th, 2003 04:54 AM #14
well, its a way to go. hehe :D medyo umaangal kasi minsan gf ko sa bumpy ride. :D
- Dec 2002
- 2,335
December 30th, 2003 01:25 PM #15bro ARB, just a rough estimate, how much would it cost to change my coils and shocks. Aim is to lift the rig by 2-3" and to improve ride. Saan ba mga shops na for 4WD? Trooper nga pala rig ko. Thanks bro and happy new year.
- 259
December 30th, 2003 01:26 PM #16ARB:
i noticed that your isuzu has only 5 leaves in the pack. my fuego has 6 leaves. bakit magkaiba tayo? fuego din ba yung sa iyo?
December 30th, 2003 06:26 PM #17
its a 4x4 96 model basically the same as the fuego suspension. i forgot to mention that got one leaf out the one with the bracket that holds the hand brake lines. i got the idea out of a strada na only three leafs are working.
January 3rd, 2004 09:50 AM #18Originally posted by ARB
sir eto na po pic, mukhang may short leaf din sya kaya lang sobra naman yata kapal compare sa pic mo. thanks
[SIZE=1]Edited pic url -Ungas [/SIZE]Last edited by Ungas; January 3rd, 2004 at 11:10 AM.
high idle RPM at engine start
