Results 41 to 50 of 71
March 8th, 2006 01:20 PM #41
i see... di ko pa natry yung magpagawa ng W terminal... you think it will work on a gas tach??
tia
March 8th, 2006 11:40 PM #42
it wont work on a gas tachometer , iba kc yung pulse , ang W terminal is for diesel tachs lang tsaka di cya ganon ka accurate pag sa alternator W terminal . get the OEM ng 2800 td na pajero un lang po masusuggest ko sir
May 2nd, 2007 11:45 PM #44
this is the pic of the injection pump as shown with yellow pointers the wiring where you can tap the tachometer, isa wiring na yan which sticks out sa gilid ng injection pump , it gave me most accurate reading. sensya di ko madescribe ung color ng wire kasi im not in manila eh pero 2 lang naman yan eh 1 has the signal needed :D
May 10th, 2007 01:24 AM #47
yun parin ang oem alternator ko hindi pako nag papalit ng higher amp.
what do you mean stable?
you mean stable bigla sya nag zero during rev or acceleration?
so far hindi sya nag kaganon.
pero theres something bothers me, yung ibang tach meron ceremony once you turn on the ignition switch, yung dsl tach moba meron?
coz akin wala eh just a single flash*shift light..
- Apr 2007
- 17
May 14th, 2007 02:25 PM #48mga bro i was able to use the normal gas tach for diesel engines,by modifying the tach itself
to accept signal from the ip. nag ADD lang ako ng diode and 2pc of capacitor and nilipat ko yun
green wire sa diode na nilagay ko. yungtach na gamitko yung autogauge din,
post ko details pag available na,kasi for now i want to consolidate my project's data to the
one available sa market,so pls help me guys here, btw my engine is 4d56NA and i used the
magnetic pickup sensor on my ip
1.my tach reads less than or equal 4000rpm b4 i shift gears, is this reading fair enough?
2.my idle rpm is less than 1000.
3.on the expressway *80kph my tach reads 3700 more or less, *1000 kph 4000rpm * 120kph itreas
4100 to 4200rpm
question, does the reading match the reading on diesel tachs installed on yoour ride?
i need your data so that i can calibrate my project to what and how atrue diesel tach reads rpm
May 14th, 2007 09:57 PM #49
does this mean its possible to use the orig tacho for a gas engine?
hope you can post more pics and details on your conversion.
May 15th, 2007 07:23 PM #50
sir tanong ko lng po kung saan kayo nakabili ng tachometer niyo and kung magkano po t.y
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
