Bro yung sa website ok yung project na yun if you can get the parts and masipag ka to install it. I do this for industrial machines. As you can see sa site nasa injector yung install nung sensor. You are are basically getting the rev/min of a shaft using a reflective material and a photosensor. Dun sa sensor you have 2 wires for supply and a single wire for output na naka kabit sa analog tachometer. yung alternator mo may W na wire? you can place a voltmeter measured against ground to see ano yung output dun. try revving the engine and see the output. kung wala or erratic then most prob its a frequency output (pulses) or digital output(on/off). Post the connection nung tach mo and the alternator and lets see how we can do it.
