Results 1 to 10 of 47
February 19th, 2003 09:44 PM #2
M-F Batteries should not and never be recharged except for your alternator. It doesn't have the right exhaust holes for the fumes and heat. Some opt to open the sealed covers which voids its Maintenance-Free, and end up with ordinary batteries after.
On the other hand, you wont have to open six holes just to check its water level. An indicator tells when it needs to be changed. This is better for those drivers who just sit and drive; and don't-know-how-to-open-their-engine-hood people.
February 19th, 2003 09:58 PM #3
Id take maintenance free any day over their regular counterparts. Just make sure that you get the high-capacity ones. Im using the red motolite right now, forgot what its called, OK naman! I cant see why anyone would get the old skool batts.
February 19th, 2003 10:22 PM #4
I believe those red ones are named Super Power M-F. Almost all batteries sold nowadays are M-F ones (the old classic refillable ones are still available). I think only the Outlast brand doesn't come up with an M-F yet.
BTW, those red ones are replaced by Motolite Gold. :D
February 19th, 2003 10:26 PM #5
Ah ok :D When i got them, they had the highest Capacity ratings. I also noticed, less yung sulfation sa mga terminals compared to the old type batts.
February 19th, 2003 11:18 PM #6
And at the strange angles we operate our vehicles in, mas maganda ang MF kasi walang leak. Yung sa Besta ko dati nag-leak kinalawang ang fenderwell. Same case with vinj's Frontier.
- 59
February 20th, 2003 12:41 AM #7MF ako, bukod sa performance ng battery it doesnt f*ck up the paint under the hood.
February 20th, 2003 01:07 AM #8
how about yun MF na motolite na tropicalized, anyone own or tried this one?
February 20th, 2003 01:15 AM #9
Yes, maintenance free batteries are definitely better. They are sealed better than low maintenance batteries resulting in less water loss and less corrosive precipitate formation. You can just drive and forget about them until of course they die down and needs replacement.
Tsikot Member Rank 3
- Dec 2002
- 636
February 20th, 2003 06:12 AM #10I've tried an AC Delco MF battery which lasted for 3 years. Brought it to battery doctors to see if they could revive it and they did- still works as a spare battery. I have to keep it charged using a "battery tender", low amp, trickle charger.
But AC Delcos are expensive so i still use low maintenance types like GS or FB batt which last about 2 yrs.
IMO, if the vehicle is used in rough roads or has hard/tough suspension then a battery will deteriorate faster due to plate damage regardless of type- MF or Low maint.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
