Yes I would think so meron gains ang porting and polishing sa diesel engines like gas powered engines.
Basic sa i/c engine is that its like a giant air pump diba? The more volume of air you flow into and out of it at a greater velocity, the more power you will make.
PnP will flow more air and more smoothly too, giving uniform flow.
And yes, as you can tell I'm a fan of Autoplus (my car is tuned there, as well as the cars of my friends, about 10 cars in all) and OK ang headworks nila.
They've done headworks on a 4D56 (tama ba yun?) and malaki ang gains, pero palit din siya intercooler at plumbing at nagtaas ng boost. Not sure ano ang final WHP niya, pero the engine revs smoother to redline (perfect for the highway) and tumalon talaga ang torque curve niya (perfect for off-roading).
ungas::: hehehe! BRING IT ON! :lol: joke lang dude!
otomatic::: thanks for the engine tips! ok sana mag swap, but i'll wait for woodfire's reply first. Swapping a 4x4's engine is not as easy as a B16A swap eh. Ang daming tatamaan. But i'll be leaving later to check out prices just the same. :D
rs sprint::: botchi, me personally, im definitely sure of the benefits of headworks. I had my B16A done dati by Mang Mente (famous in the racing underground). Kaya lang a lot of people are telling me not to do it, including my mechanic. Oh well.... i hope the engine swap is within budet para moot and academic na lahat to :D Thanks for the input dude!
rs sprint::: Yup! He's THE MAN! galing nyan gumawa pare! The ultimate head guy! Di pa taga maningil! Nice suggestion on the head dude! :D But i think im gonna wait till someone does it (diesel headworks) and wait for results before doing it myself.... sayang gastos e :D
if you do decide to swap engines,try Diamond Motors Santolan Branch (Main Service Center). I can introduce you the Mr. Art De Los Angeles, their head/VP for Technical and Mechanical Services.
Yes, you need to change your tranny if you swap. Yes you will have to change engine mounts for 4M40.
Before you proceed, please take time to scout around for good surplus shops (banawe, araneta ave., pampanga c/o Kimpoy, and cavite along coastal road (I read about these shops along coastal in one of the threads in Kotse.com)
Once you have a short-list of shops, bring along a good mechanic who can discern the good engines from the lemons. Aside from myself, you can try contacting Doc Diesel's bro in Betan Makati. Im sure they have a good mechanic specializing in Diesel engines. You can also contact Hanson in Banawe since he has in his employ some Diesel mechanics.
The 4M40 is significantly better than 4D56 in terms of performance but also in emission. It can better handle the hefty weight of the pajero.
woodfire::: thanks so much! Anyway, nag canvass na ako and it looks like the swap will cost a lot more than what i can afford at this time :| Im proceeding with the overhaul. As of present, medyo mahal pa mga parts ng 4M40, not to mention not as widespread. Perhaps in a couple of years, medyo feasible na po to para sakin. :D thank you so much sir!
MODEL PAJERO
GENERAL SPECIFICATIONS 2WD
Overall Length mm 4735
Overall Width mm 1775
Overall Height mm 1910
Ground Clearance mm 215
Wheelbase mm 2725
Gross Vehicle Weight kg 2550
Seating Capacity person 10
Fuel Tank Capacity liter 92 liters
WHEELS AND TIRES
Tires 7.0JJ x 16" Alloy Wheel
Wheels 265/70 R16 (A/T Type)
ENGINE
Model & Type 4M40 SOHC, Intercooled turbocharged, Diesel
Fuel System Rotary Type Injection System
Displacement cc 2835
Bore x Stroke mm 95.0 x 100.0
Compression Ratio 21.0 : 1
Max. Power kW(PS)/rpm DIN Net 92(125)/4000
Max. Torque Nm(kg-m)/rpm DIN Net 292(29.8)/2000
TRANSMISSION
Drive Wheels 2WD
Type 4-Speed Automatic
Gear Ratios 1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
Reverse 2.393
Final 4.900
SUSPENSION
Front Independent Double Wishbone with Torsion Bar
Rear 3-link Coil Spring with Stabilizer
Damping Front & Rear Cockpit Adjustable Shock Absorber
BRAKES
Front 15" Ventilated Disc with 2-Pot Calipers
Rear 16" Solid Disc (with internal drum)
Brake Booster 7" + 8" Master Vac
STEERING
Gear Type Ball & Nut Gear Type with Power Steering
Steering Wheel 4-Spole Leather Wrapped with Airbag
Tilt Adjustment Standard
SAFETY
* Driver's Side Airbag * 3-pt. ELR Seatbelts * Side Impact Beams * Laminated Windshield
INTERIOR
* Full Grain Leather Seats (Improved Design) * Moulded Floor Mats * Tire Pressure Monitor System (TPMS) * Folding Type Rear Seats * Door Pockets * Central Locking * Ignition Key Illumination * Lights Off Reminder * Rheostat * Child-Proof Lock * Digital Clock * Split-type Second Row Seats * Power Door Mirrors * Power Windows * Power Door Locks * Ashtray & Cigarette Lighter * Cupholders * Maplamps * Rear Demister * 6-way Power Adjustable Seats (Driver's Side) * Rear Separate Headrest * Assist Grip * Center Console
EXTERIOR
* Spare Tire Carrier with Cover * Front Foglamps * 2-Tone Body Paint * Headlamp Washer * Chrome Door Handles & Drip Mouldings * Chrome Plated Grille * Chrome Plated Side Mirrors & Windshield Moulding * Towing Hook (Front & Rear) * Hood Scoop * Integrated Aluminum Side Stepboards
AUDIO SYSTEM
* Power Antenna * MMAD In-Dash CD/MP3 Player * 6 Speakers (with 2 pcs. delta mounted tweeters)
sir ope ds help. ng copy paste lang po ako. gling po ito sa mitsu website
rs sprint::: yung ganitong specs ng bore vs. stroke is designed to produce power sa low end. Unlike oversquare designs na mas malaki ang bore vs. stroke :D Off topic::: botch check out my ex-ride www.pbase.com/mann2/my_eg :D
pjxtc::: wala pa po sa budget ang 4m40 sir. :| Hindi po kasi straight engine swap eh. I have to replace the tranny, transfercse, mounts and a lot more things..... but the idea still tickles my mind :lol: In the far future po siguro, kapag medyo mainstream na yung 4M40. As of now ang ginhawa ng 4d56. Nagkalat ang parts and very very simple to maintain :D
Kasi even Mitsubishi's 4G63 engines have an 88MM stroke tapos 85MM bore lang. We have problems of the crank breaking at sustained high RPM runs past 7000 RPM eh, and there is a lot of power gaiend when we rev to 8K with upgraded valvetrain. Kung crank ang weakest link because of physical limitation (primary vs secondary motion harmonics).
4.9:1 pala ang final ng 4x2 pajero, mas low speed pa sa genI ko na de gaso 4.875 pero humihingi pa ng isang gear 120kph* 4,000rpm na agad. why kaya?:roll: any body can enligthen me. thanks
but haven't test at high speed pa with the new clutch, sana bumaba na rpm ko!:wink:
