MODEL PAJERO
GENERAL SPECIFICATIONS 2WD
Overall Length mm 4735
Overall Width mm 1775
Overall Height mm 1910
Ground Clearance mm 215
Wheelbase mm 2725
Gross Vehicle Weight kg 2550
Seating Capacity person 10
Fuel Tank Capacity liter 92 liters
WHEELS AND TIRES
Tires 7.0JJ x 16" Alloy Wheel
Wheels 265/70 R16 (A/T Type)
ENGINE
Model & Type 4M40 SOHC, Intercooled turbocharged, Diesel
Fuel System Rotary Type Injection System
Displacement cc 2835
Bore x Stroke mm 95.0 x 100.0
Compression Ratio 21.0 : 1
Max. Power kW(PS)/rpm DIN Net 92(125)/4000
Max. Torque Nm(kg-m)/rpm DIN Net 292(29.8)/2000
TRANSMISSION
Drive Wheels 2WD
Type 4-Speed Automatic
Gear Ratios 1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
Reverse 2.393
Final 4.900
SUSPENSION
Front Independent Double Wishbone with Torsion Bar
Rear 3-link Coil Spring with Stabilizer
Damping Front & Rear Cockpit Adjustable Shock Absorber
BRAKES
Front 15" Ventilated Disc with 2-Pot Calipers
Rear 16" Solid Disc (with internal drum)
Brake Booster 7" + 8" Master Vac
STEERING
Gear Type Ball & Nut Gear Type with Power Steering
Steering Wheel 4-Spole Leather Wrapped with Airbag
Tilt Adjustment Standard
SAFETY
* Driver's Side Airbag * 3-pt. ELR Seatbelts * Side Impact Beams * Laminated Windshield
INTERIOR
* Full Grain Leather Seats (Improved Design) * Moulded Floor Mats * Tire Pressure Monitor System (TPMS) * Folding Type Rear Seats * Door Pockets * Central Locking * Ignition Key Illumination * Lights Off Reminder * Rheostat * Child-Proof Lock * Digital Clock * Split-type Second Row Seats * Power Door Mirrors * Power Windows * Power Door Locks * Ashtray & Cigarette Lighter * Cupholders * Maplamps * Rear Demister * 6-way Power Adjustable Seats (Driver's Side) * Rear Separate Headrest * Assist Grip * Center Console
EXTERIOR
* Spare Tire Carrier with Cover * Front Foglamps * 2-Tone Body Paint * Headlamp Washer * Chrome Door Handles & Drip Mouldings * Chrome Plated Grille * Chrome Plated Side Mirrors & Windshield Moulding * Towing Hook (Front & Rear) * Hood Scoop * Integrated Aluminum Side Stepboards
AUDIO SYSTEM
* Power Antenna * MMAD In-Dash CD/MP3 Player * 6 Speakers (with 2 pcs. delta mounted tweeters)
sir ope ds help. ng copy paste lang po ako. gling po ito sa mitsu website
