Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    guys,
    do you know where i can get this?surplus for 2nd gen pajero?pwede rin daw yun pang delica.need it asap.thanks
    If your Pajero uses the Super Select system (the one with the center difflock) then it does not have freewheel hubs. It uses a CAD (central axle disconnect) to be able to drive in 2H. Putting freewheel hubs on the Super Select system disables the ability to shift-on-the fly. If for some reason you are having trouble with the SS system, just put it in 4H (not 4Hlc) as this is the 'default' mode of the front axle.
    But if you have the conventional 4x4 system, then even the ones from Stradas will work. Your choice if you want auto or manual. Siyempre mas preffered ng off-roaders ang manual. You can even get name-brand hubs from stores like Armark.
    bought mine sa banawe 2000 yata each.
    auto hubs.
    Aug 2003
    auto hubs.
    Sir Kimps dati bang manual hub sayo?
    kung auto hubs binili mo...mayroon bang additional switch sa loob para magamit mo yung 4wd? yung parang dial switch sa ibang rides?
    tnx sanay po kasi ako sa manual hehe
    sensya na po sa tanong...
    otep,
    can you pls explain it to me further?or in lay mans term?kce super select yun pajero,tapos our mechanic installed the free wheeling hubs,well,it runs fine naman,know he wants to install one in the other pajero.what are the pros and cons again?thanks
    and nag inquire ako sa motorix and bestcolt,wala daw silang available na free wheeling hubs,then i called up one surplus shop,meron daw silang surplus,6.5k set.and also 4m40 gearbox for 12t,is it a good deal already?
    Yikes! Nilagyan niyo ng hubs yung Super Select? Bye-bye Super Select na iyan kung ganun. Ginawa niyo nang conventional 4WD. Super Select has the advantage of being shift on the fly up to 100kph and that it can be used on paved roads (i.e. madulas dahil sa ulan, may mudslide, etc.).
    Ano ang logic ng mechanic for installing the hubs? If the front wheel icons on the Super Select indicator are flashing while driving, it usually means you have a vacum leak or sensor problem. It does not warrant putting in freewheel hubs as the system was designed to function without one.
    Maybe you need a new mechanic? :D
    Btw, some vehicles with conventional 4wd systems come from the factory without freewheel hubs (i.e. government models of the Pajero and Strada). They are retrofitted with hubs (manual or automatic) in the interest of less driveline drag and better fuel economy. Something that the Super Select system has solved by employing a CAD (central axle disconnect) which allows the front axle to freewheel.
    OT: meron bang nabibiling locking hubs for patrol sa banawe?
    Signature
    Kung hybrid-type ang hanap mo (yung OEM), I'm not sure. Pero kung yung mga conventional na hubs (either manual or automatic), madaming surplus na Aisin hubs sa Banawe. Matter of finding one that will fit na lang siguro ito.
    Btw, most four wheelers swear that Aisins are better than hubs from AVM, Warn or Superwinch or most other name-brand hubs.
    do you mean kapag manual ang nabili ko, laging manual. and auto, laging auto? yung sa akin ngayon di ba parang naka auto na ito?
    Signature
    Sir boybi,
    Wala ka namang freewheel hubs ngayon, eh. So its basically the same as having either manual or auto pero parating nasa LOCK mode kasi wala siyang unlock mode.
    masama ba kapag laging naka lock?
    Signature
    Hindi naman. Mas less effecient lang. Pero wala pang 5% siguro. Sa Pajero kasi 2% lang daw ang bawas sa fuel economy when you run it in 4H all the time compared sa 2H setting. Some models do not even come with freewheel hubs. Mostly ito yung mga basic models na gamit ng gobyerno.
    nope kase na ka lock naman yan ever since you bought the vehicle and nothing has happened pa naman and so are other 2wd patrols. its just a matter of additonal friction that is not that big in terms of fuel efficiency.
    so kapag napa convert ko na to 4wd yung akin without installing the front locking hubs, di ako magkakaproblem?
    yung mga new patrols daw ngayon wala ng laman yung front diffs. totoo ba ito?
    Signature
    as long as the front diff flange is turning when you turn the front wheels may diff yan. and as long as open ang front diffs.
    Mar 2003
    Just want to install a manual free wheeling hubs sa strada in lieu of the auto hubs para ma-enjoy ko ung 2L option sa paved road. Is it feasible? Nag-inquire na ako sa mga offroad shops kaso wala daw available na pang-strada. Kung gusto ko daw maghanap daw ako ng surplus na pang pang Gen1 na strada o pajero sa banawe. Mag-fit kaya ito if ever meron?
    Sir mangyan,
    Yes they will fit. I don't know the exact model number but it is manufactured by Aisin.
    mangyan,
    tamang tama, si sir bogart nahahanap ng auto hubs.
    mag swap na lang kayo
    otep,
    sa front hubs ko kce,naka sulat automatic,i mean not the manual lock and unlock?what does it mean?do i make sense here?im kinda confused.
hub lock freewheel?
