Results 1 to 10 of 15
September 22nd, 2005 02:36 PM #1
Hi everyone!
I drive a '00 Frontier 2.7E na color white. Im planning on buying a new set of wheels. This will be my first time buying kaya wala ako idea about the prices and which store to buy, so might as well get opinions here first para hindi ako
maloko.
My tires are Dueler AT 235/75R15. 23+K lang budget ko and I only use my pick-up for city driving. Im interested in the chrome American Racing(or any other brand na OK at mas mura?), not sure about the design and size/width (suggestions please.). Gusto ko lang lumabas un tires sa fender for a meaner look. Around 1 inch na labas ok na un or ano ba ok para hindi magka-problema?. What size should I buy, 15X8 or 15X7? Meron ba effect ang wider wheels sa handling and magkakaroon ba ito ng problema, e.g : rubbing the fender, tension on suspension/other parts? Should buy alloy or steel?
Lastly, saang stores OK bumili na mataas mag presyo sa trade-in ng stock wheels?
Any help is appreciated. Thanks in advance!
September 22nd, 2005 04:52 PM #2
Freddie's Tire Supply (Evangelista St. Makati - 7504601 look for Jerry)
I would recommend you have the wheel and tire combination of your choice measured and fitted on your ride so as to eliminate guesswork on whether the new combo will create problems with you ride.
September 22nd, 2005 05:06 PM #3
23K is more than enough for your goal IMO. Since you're already using 235/75R15 Bridgestone Dueler a/t's you can very well keep these tires already (no need to upgrade to larger/wider tires anymore).
What you should concentrate on are the rim types you'll consider then: the type of rim that will give your car a wider stance would be one with a negative off-set. A more negative off-set will put the mounting point of the rim deeper so the tires will stick out more.
You can shop for American Racing wheels if you look around Evangelista and Blumentritt. There's also a cheaper but similar brand, AWC. If you're in QC/Cubao, you can check out DKC Tires on P. Tuazon before Ali Mall.
The Frontier 2.7E I use has the OEM 15" rims of a 1995 Nissan Safari on similar 235/75 Desert Duelers and i already achieved a wider stance.I traded in my old, balded tires and rims and shelled out around 14K three years ago (including the tires na).
September 23rd, 2005 12:42 PM #4
Thanks for the replies! I'll check Freddie's TS and other Evangelista stores this weekend.
vinj, nice to know another Frontier driver. I'm assuming that's your Frontier in nissanbayan gallery? Nice car pare.
You have the tel.number of DKC? I'll try to call them first before I visit their store. Siguro I'll just have to fit the wheels/tires first to check kung walang magiging problema.
O/T, I've read in an old thread regarding your shocks mod. What brand nga ulit ginamit mo? Hindi na ba matagtag? Lagi nahihilo un mga pasahero ko sa backseat dahil sa sobrang tagtag.
Thanks again!
September 23rd, 2005 01:13 PM #5
DKC: 421-3549
Yup, that's my Frontier in the gallery (meyo luma yung pic).
The shocks i used are KYB Gas-A-Justs... costs less than 1K in Banawe. The shocks helped in controlling the rebound more but to lessen the jolt in the rear, you'll have to invert one leaf spring "molye".
Tsikot Member Rank 4
- Oct 2004
- 2,315
September 25th, 2005 12:18 AM #6try mo din rota's. Ganda din designs nila. Ako din gusto ko na magpalit ng wider rims and tires. Pwede po ba lagyan ng spacers yun para magmukhang malapad at labas ang gulong? Teka 4x2 ba ride mo lemon? kasi yun gulong ko konti lang space pag nilaparan pa baka sumayad na sa fender flares kaya pinalift ko ng konti, torsion crank lang at palit hangers.
September 25th, 2005 07:43 PM #7
With 235/75R15's no problem with suspension play. You can crank up the front torsion bars a bit if the front is drooping a bit too low (common setting with most Frontiers). I cranked mine by half an inch just to match the height with the rears.
September 26th, 2005 03:23 AM #8
Sup quiksie, 4x2 un ride ko. Stock ba un nakakabit na mags sa ride mo?
Went to Evangelista last Saturday, walang stock ng AR wheels un mga stores. I'll try Blumenttrit this week.
Sir vinj, I read on NB na meron discount ang Rota for NB members? how do I avail of the 20% off on Rota wheels? Interested ako dun sa Lightning model.
Btw, wala bang Frontier club?
Thanks for the replies.
September 26th, 2005 08:58 PM #9
Is AMS a good wheel brand? Meron OK na design ng AMS sa Auto Options Timog, kaya lang ang baba ng kuha nila sa stocks wheels ko pag dun ko sa kanila itrade-in.
Would my 235/75R15 AT tires fit on a 15x8/8.5 rims?
- Jul 2005
- 499
September 26th, 2005 11:01 PM #10Originally Posted by Lemon
xtrail w/ 18" mondera blackhawk magsLast edited by beebs; September 26th, 2005 at 11:03 PM.
Depends on the level of resistance....& clout of those who'll be put to sleep?[emoji848]🤫 Sent...
[AI] Here's what they'll check during MVIS...
