Results 1 to 10 of 10
July 15th, 2004 06:40 PM #1
sir,
my hilux needs electrical repair:
1. the oil pressure gauge is out of order (bka sending unit lang ang sira)
2. the RPM (tachometer?) is also out of order
3.
July 15th, 2004 06:44 PM #2
(sorry mods, na enter kaagad)
3. when i engage the transfer case to 4H or 4L, the 4WD does not light up. when i place it in N, it lights up.
4. the gas level gauge indicates half tank even though its filled up to the brim
5. low and high beam are mixed up.
talk about electrical woes.
can anyone recommend an electrician who can work on the electricals of my rig? TIA
July 15th, 2004 08:48 PM #3
I think only problem #2 & #5 will be entertained by electricians. Yung problems #1 & #4 can be handled by your suking mechanic. While problem #3 sa 4WD mechanic ang gagawa. Team X Manila suggests someone named Edwin M. Better call Armark for more details.
- Jul 2004
- 3
July 15th, 2004 10:45 PM #4to problem # 1 to test kung gage o sensor ang me problem pull the wire from oil sensor then contact it to the engine body if the meter deflect if ignition switch is on it means the meter is ok replace your oil switch
July 16th, 2004 09:52 AM #5
thanks sir oyledz. sira nga sending unit
sir ungas: san ba nakakabit yung rpm meter?
July 16th, 2004 09:59 AM #6
quindoyos, you can try wizzard along timog avenue. if you are coming from e rodriguez, make right turn at timog and drive 100 meters. it is past the dallas carwash shop.
just try to come in early since there are a lot of customers...
July 16th, 2004 02:56 PM #7
Sa aking pagkakaalam may ibang sasakyan na nakakabit ang tachometer sender sa transmisson. Yung iba cable type paakyat sa dial. May ibang sasakyan naman electronic na, wire lang ang papasok sa tachometer, at bronze tips ang nagpapagana sa dial.
July 17th, 2004 06:06 AM #8
kayang kaya yan sir kina kong obet
yung pinuntahan natin dito sa pampanga
kaya lang malayo sayo.
July 25th, 2004 11:12 AM #9Originally posted by ECG
- Aug 2003
- 9,720
lotus elise all the way! 2004 edition
Lotus returns...
