Results 1 to 10 of 10
    Jan 2004
    sir,
    my hilux needs electrical repair:
    1. the oil pressure gauge is out of order (bka sending unit lang ang sira)
    2. the RPM (tachometer?) is also out of order
    3.
    Jan 2004
    (sorry mods, na enter kaagad)
    3. when i engage the transfer case to 4H or 4L, the 4WD does not light up. when i place it in N, it lights up.
    4. the gas level gauge indicates half tank even though its filled up to the brim
    5. low and high beam are mixed up.
    talk about electrical woes.
    can anyone recommend an electrician who can work on the electricals of my rig? TIA
    I think only problem #2 & #5 will be entertained by electricians. Yung problems #1 & #4 can be handled by your suking mechanic. While problem #3 sa 4WD mechanic ang gagawa. Team X Manila suggests someone named Edwin M. Better call Armark for more details.
    Jul 2004
    to problem # 1 to test kung gage o sensor ang me problem pull the wire from oil sensor then contact it to the engine body if the meter deflect if ignition switch is on it means the meter is ok replace your oil switch
    Jan 2004
    thanks sir oyledz. sira nga sending unit
    sir ungas: san ba nakakabit yung rpm meter?
    quindoyos, you can try wizzard along timog avenue. if you are coming from e rodriguez, make right turn at timog and drive 100 meters. it is past the dallas carwash shop.
    just try to come in early since there are a lot of customers...
    Sa aking pagkakaalam may ibang sasakyan na nakakabit ang tachometer sender sa transmisson. Yung iba cable type paakyat sa dial. May ibang sasakyan naman electronic na, wire lang ang papasok sa tachometer, at bronze tips ang nagpapagana sa dial.
    May 2004
    kayang kaya yan sir kina kong obet
    yung pinuntahan natin dito sa pampanga
    kaya lang malayo sayo.
    Jan 2004
    tamang tama sir, punta ako jan sa wednesday for the snorkel. thanks for the info! kita tayo sir!
    Aug 2003
    can anyone recommend a shop sa pasay?
Electrical Repair
