Results 1 to 10 of 14
July 27th, 2003 12:12 AM #1
Does the use of DOT 4 brake fluid shorten the stopping distance of a vehicle compared to the use of DOT 3?
Thank you.
July 27th, 2003 12:47 AM #2
maybe a firmer brake feel and less brake fade but to shorten the stopping distance of a vehicle would require better tires that are grippier, not better brake fluid.
DOT4 vs DOT3 will simply give better resistance to brake fade due to high temperatures in your brake system, particularly in your calipers.
- 400
July 27th, 2003 01:07 AM #3aside from tires also try better brakepads. if you're using mud or a/t tires its the tires that is limiting your braking, not the brakes... walang kwenta ang on-road grip ng m/t at a/t tires, andali padulasin.
July 27th, 2003 10:06 AM #4
is it true that dot 4 brake fluid is prone to condensation? or not suited for everday used car. please confirm this peeps.
July 27th, 2003 11:03 AM #5
AFAIK, the difference between them is the temperature ratings. DOT4 is superior. Yan gamit ko sa CBR ko before. Stock cars only require DOT3. Havent tried DOT4.
July 28th, 2003 02:18 AM #6Originally posted by ARB
Unless you plan to do some serious track/ high performance road driving, it'll be better to stick to the stock fluids then concentrate on a brake pad upgrade or even steel braided lines.
Heres a thread that can give some info: http://www.nissanbayan.com/forums/in...f=6&t=1239066&
July 28th, 2003 11:28 AM #7
I use DOT4 on my rig, luckily I don't see any condensation in the process.
Mas mataas daw ang temperature range ng DOT4 compared to DOT3. Which means better constant braking power, lalo na wala akong maaasahang brake grip on my mud tires.
July 28th, 2003 11:34 AM #8
DOT3 is tougher than DOT4 (against condensation, etc.). Buti DOT4 generally performs better.
Pwede na sakin ang DOT3.
July 29th, 2003 01:32 AM #10
I remember hearing before that MB does use a different brake fluid (not DOT 3).
high idle RPM at engine start
