Results 11 to 20 of 25
- 55
April 29th, 2003 01:35 AM #11yes my tire size is 245-75-r16 and it actually says 80psi. is this right?
i just changed my oil last week. used 6liters but after i checked, it was at the empty level. so i added 2 more today. will check tomorrow if it's at the right level already. i'm sure it doesn't have any leak and should not be burning the oil. that's too much in such a short span of time.
will get back to you guys for more inputs.
as of the calibration thing for 4jg2's, yes and no.
we calibrate the mechanical type of injection pumps for 4jg2 but we don't calibrate the EFI version of it, which i have.
regards,
david
April 29th, 2003 01:45 AM #12
Lotus Editions have different suspension settings as well as trim differences from regular Troopers. They're the sportier bunch in the Trooper series.
Tsikot Member Rank 3
- Dec 2002
- 636
April 29th, 2003 11:39 PM #13hanson,
8L is what the 4JX1 uses, possibly yours is a transition model.
April 30th, 2003 09:31 AM #14
i saw a 4jg2T engine in blumentritt sta. cruz kumpleto pa yung makina with intercooler ganda e.
tinanong ko ang price.......................
perari: bossing magkano to (sabay turo sa makina......)
tindero : wan tin po. (110k daw) 8O
perari: nakampucha! (sabay alis) :mrgreen:
April 30th, 2003 02:05 PM #15
80 psi is the maximum you can put in the tire. But its not practical. I only max out my spare so I can steal some air from it in case one of my road tires need it (I have this hose thingie for that purpose).
- Dec 2002
- 2,335
April 30th, 2003 02:40 PM #16Originally Posted by hanson
OEM tire 245/70R16 1075 tyres
Lotus edition: 33.6 (front and rear) cold tyre pressure (tyre pressure when a vehicle has not been driven more that 2.0 km and after sitting for three hours or more.
Add 2.8 psi for hot tyre pressure (when tyre has travelled more than 2.0 km).
Other than Lotus: 29.4 front 33.6 rear
Big Horn manual itong inof na ito.
Trooper manual from the U.S 30 psi front 35 psi rear
:P
HTH :D
April 30th, 2003 06:24 PM #17Originally Posted by OTEP
havent tried that.................. otep ndi ba nag c-crack yung gulong? kasi pag mga 50 tatakot na ko e.
April 30th, 2003 06:46 PM #18
fierari
Yan engine na yan.... sa lumang bighorn pa yan.. ah decommission unit na siya.... pero kasi siguro kaya mahal dahil sa INTERCOOLLER niya
Garyq.
Sir laki na talaga kasalanan ko sayo........ galing mo sir ah kumpleto ang ionformation mo.... you are the expert sa bighorn
- 55
May 5th, 2003 12:10 AM #19i put mine 6.5ltrs. i have to check the tires. damn! i don't know if it's the suspension or the tires but i have driving through the potholes. my cd keeps on skipping! i am finding the suspension quite hard.
david
- Dec 2002
- 2,335
May 6th, 2003 01:01 AM #20Originally Posted by hanson
Thanks!
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
