Results 1 to 10 of 25
Threaded View
- Jun 2004
- 103
July 2nd, 2004 09:48 AM #1I have a '97 L200 all stock. This has coil springs in front and rear leafs. I have 14" tires and am thinking of replacing it with 15" tires for a slightly higher ground clearance. Is it possible to lift this a bit? I know that I can use longer shackles on the rear leafs but how do I lift the front with the coil spring suspension?
***y welds! Apparently the subcon that makes the part replaced a worn welding tip but did not...
Chery returns to PH
