Results 31 to 38 of 38
- 350
September 10th, 2003 10:43 PM #31thanks for the replies, ganun pala yun!
what if bigla mo kailangan mag stop for a few seconds, ok lang ba idle ang engine? di pa rin papasok water?
September 10th, 2003 10:50 PM #32
Ample clutch if your really have to stop and place in neutral position. Hindi naman basta basta mamamatay ang makina. Unless, palyado ang makina na ginagamit mo. You can still feel the engine run at its norm rpm's.
- Jul 2003
- 579
September 11th, 2003 04:28 AM #33you can never tell kung papasok water. you know, trying to memorize all these things really takes the fun out of water crossings. me, i just go for it. i even idle and fully disengage the clucth at waist high water. Sabi nga nila, your vehicle is just a tool. you can have the best tool but if you don't know how to use it, bale wala. as for learning how to drive, these are all just guidelines. it all comes to how much you know your vehicle. lahat ng tinuro sa mga clinic, di ko sinusunod. such as downhill descent, sabi low gear ako 2h engine brake and brake. alam ko kasi limits ng car ko. alam ko how much it would take to lock the tires etc. sa baha. sugod mo. pag tumirik, charge to experience. NEVER EVER LET THE WATER GO PAST THE INTAKE. bayaan mo na lumubog exhaust. bayaan mo na mabasa carpet. huwag lang talaga intake.
- Jul 2003
- 63
September 11th, 2003 05:10 PM #34Sir Jondy,
Naalala ko tuloy yung sumunod sa aking na kotse sa Malugay St. Makati hehehe. Lalim din kasi ng baha dun galing riles ng tren pag walang tigil ang ulan. Binubusinahan pa nga nya ako akala ko may problema yun pala susundan lang nya ako para mas mababa na yung tubig sa likod ko hehehe. Sarap talaga ng mataas ang sasakyan........ kahit hindi 4X4......... pero the best pa rin 4x4 :")
- Jul 2003
- 26
September 11th, 2003 05:44 PM #35saan banda sa southwood yung mataas ang baha?
mapapalipat kasi ako sa bandang dasmarinas eh...via southwoods then carmona ang daan ko...yariii!!
September 11th, 2003 05:58 PM #36
hmm... buti na lang wala akong clutch.. bwhaha... A/T diesel... wagon... basta baha.. sugod lang... alalay lang .. ehhe
September 11th, 2003 06:10 PM #37Originally posted by Mr_Revo
papuntang juana, rosario, stone crest, chrysanthemum, pacita
yung may baha na yun.
- Jul 2003
- 26
high idle RPM at engine start
