Results 21 to 30 of 37
September 13th, 2003 12:21 AM #21
Ayan na naman yang Venturi effect na iyan ha. 1960's pa ginigimik iyan hanggang ngayon buhay pa!
September 13th, 2003 09:46 AM #22
Watch Magandang Gabi Bayan tonight, may feature daw yun yung added turbo pressure in the canister, you be the judge. :bwahaha: :bwahaha: :bwahaha:
September 13th, 2003 11:51 PM #23
I could almost hear the music playing in the background ... "Send in the Clowns"...
September 14th, 2003 05:47 AM #24
Napanood ko ang MGB, pero para sa gas lang naman yun. Mukhang ok, but then again, I have my doubts.
- Feb 2003
- 144
September 14th, 2003 02:51 PM #25ano ba yan...nde gumagana yung mga products na yan, yung aerogas thingy eh kopya lang yan nung late80's-early 90's invention ng iusang pinoy that hit it big sa mga probinsy...tapos nakita ng mga taiwanse, ayan gumawa ng "refined" version, mas maliit and mas cute tingan,i have one of the old versions myself
yes it give u a butt feel na mas mlakas hatak ng kotse, but ihavent confirmed it with dyno tests yet, tama nga kayo na ginagawa lang na mas lean ang mixture, like putting a hole in the intake after the MAF =) it uses a cut out scotch brite for its filter heheheh kewl...parang venturi effect din yung nangyayari, kasi may parang perforated na takip yun na bumubukas lang kapag nirerev yung car so sa idling minimal effect lang yun...share lang...
September 14th, 2003 10:58 PM #27
Para siyang blow-off valve kahit wala kang turbo. Hehehe. It keeps manifold pressure from turning into vacum when you let go of the throttle.
Tama ba?
- Feb 2003
- 144
September 15th, 2003 08:27 AM #28actually the vacuum will suck more air through the "aerogas" pag mas mataas yung rev (venturi effect), therby minimizing the vacuum inside and making the mixture leaner kasi nga after the MAF nakakabit, (kung baga cholorum yung pumapasok na hangin) heheheh
and yes it also minimizes the vacuum pag nakaidle parang may butas ka... nagyari sa akin dati habang tumatakbo nakalas yung old skul na"aerogas" kuno, ayan namatay yung makina..heheheh tapos ayaw na mag start, pag bukas ko ng hood buti na lang sumabit sa mga cable dun (yung pag open ng hood) tsk tsk...
December 23rd, 2004 07:44 AM #29
Businessman talaga tong si Mr. add616reneb.. puro tungkol sa less-polluting power-adding & fuel-saving devices ang mga post. Try doing a search of all his posts.
I wish I could be like him.
December 23rd, 2004 09:26 AM #30
Originally Posted by kiper
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
