Busted shocks does not produce squeaking sound. Dried up bushing will cause it to squeak.
With your own weight, dip one corner of your vehicle. It should bounce back up to its normal position. Pag nagdalawang bounce bago bumalik sa normal position, sign of weak shocks. Pag umabot sa 4 bounce, busted shocks na. Or you can visually inspect the shaft rod for excess oil.
Pag ball joint ang cause, usual sound ay lagatok pagkadaan sa lubak. Naglalagatukan ang parts, indicating that the ball joint is loose and may need regreasing or worse, replacement.
bok marami ka nang upgrade sa hilux mo ah, oks na yung alarm ? ? ? natuloy ka ba sa kapalangan?
ok na bok, nakakabit na. natuloy ako one time sa dau, hanap ng parachute. walang T10B o MC1, square lang. EB kami ni ECG(olivedrab), tugi, kimpOy, jeepcruizerph at lcvx80
