Results 21 to 30 of 60
- Jun 2017
- 153
February 6th, 2018 12:57 AM #21
- Jan 2009
- 123
- Aug 2012
- 2,767
February 9th, 2018 05:04 PM #23
February 9th, 2018 05:29 PM #24
Whoa! Hold on my friend. Do not use a garage jack as you would with the scissors jack that came with the car. First, the garage jack average height ranges around 17 - 17 1/2 inches from the finished floorline whereas the car's jack only raise to around 10 inches. Second, do not use a garage jack at any one corner of the car specially unibody/unitized body. The car's frame can twist so much that might crack the windshield or rear window or delaminate it away from the windshield/window frame causing water leaks when it rains. If you watched this from Scotty Kilmer, don't do it for reasons just stated.Last edited by jick.cejoco; February 9th, 2018 at 05:31 PM.
- Aug 2012
- 2,767
February 9th, 2018 05:32 PM #25
February 9th, 2018 05:39 PM #26
- Jun 2017
- 153
February 10th, 2018 01:46 PM #27Ahhh ganon po pala yon thanks sir for the information.
Diko masiyado gets sir, nakahiram po kasi ako ng floor jack sa kaibigan ko ganto po siya Prostar 2 Ton Floor Jack 3 Max Lift Height Red with Blown Case | Lazada PH. Hindi po ba pwede gumamit ng ganto pag isang side lang ang iaangat? Tinanong ko kasi yung mechanic sa may goodyear samin ang sabi is wala daw jack point ang honda city sa front? BTW ano po ba ang garage jack?
Ano po ba ang garage jack? and ano po ba ang pinaka tamang way sa pag jack up ng sasakyan?
February 10th, 2018 04:19 PM #30
Sir Jick, yung jack stand wala na dun sa reinforced jacking point, ok lang ba yun?
Also, everytime i have my oil or AT fluid changed they just jack it up on one side, now i relaize after your post, that this could be the reason why the top left side corner of my windshield is leaking. tsk.. tsk...
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
