Results 1 to 10 of 34
July 9th, 2003 11:38 AM #2
There are no tell tale signs if the timing belts needs replacement. Most manuals dictate from 80K kms. to 100K kms reading from your odometer.
If your vehicle runs for an average of 10K kms. a year, you should be wary of changing them on the 8th or 9th year.
July 9th, 2003 11:55 AM #3
between 80,000 and 100,000 kilometers is the appropriate time to replace your timing belt and other related parts.
What I normally do, I visually check my timing belt, especially now that I'm hitting 70K, for signs of cracks and other abnormal appearance that would indicate that it's time for replacement.
Visually check your T-Belt and below are the tell tale signs of a T-Belt due for replacement (got this from the net)
1. Hardened backing rubber (the rubber appears glossy and non-elastic. If you scratch it with your fingernails, it will not leave any mark, this means it's time for replacement)
2. Surface cracks on the backing rubber
3. Cracks on the tooth bottom or missing teeth.
4. Cracks on the belt sides or abnormal wear on the belt sides. Note: The sides of the T-Belt are normal if they are sharp as if they were cut by a sharp knife.
HTH
July 9th, 2003 11:59 AM #4
imo.
70km or after 5 years (assuming brandnew mo nakuha), which ever come first. Kung low mileage ang car most likely 5 years.
Kung second hand mo nakuha ang car mo, ask the previous owner, or better change it na din as part of prventive maintenance.
ung nakuha ko nga na 2nd hand eh (52km) papalitan ko na ng timing belt, bearing tensioner, aircon and alternator belt this coming sunday. di ko na sinama ang waterpump...wala na akong pera... :drool:
July 10th, 2003 08:09 AM #7
guys,
is it true that the isuzu 4jb1t uses timing chain instead of a timing belt? is a chain more durable than the belt?
July 10th, 2003 09:55 AM #8
Beetols,
Ung hilander uses timing chain, I'm not sure what your ride uses though. Pa-check mo nalang sa mechanic mo.
Ako I changed my T-belt at 60tkms. My next change will be at 120tkms. I used orig mitsu belt.
- Jul 2003
- 573
July 14th, 2003 03:26 PM #10Inspect the timing belt area for oil leaks and oil on the timing belt.
Replace the timing belt after correcting the oil leak problem. additional tip. On some make of cars, the timing belt also drives the water pump.
How about 97 LXi?
Civic horsepower
