Results 11 to 18 of 18
Tsikot Member Rank 3
- Oct 2003
- 699
October 25th, 2005 04:38 PM #11ganyan din problema ng kotse ko dati (civic). nung may pinaayos ako, tinanggal ng lokong mekaniko ang foam na humahawak sa mga metal connectors ng door lock (para siguro mas madali ilagay ang door panel) kaya nag-ra-rattle. nung nilagyan ng foam, tahimik na uli.
October 26th, 2005 07:13 PM #12
this is a picture of it...
wala akong screw makita dito.
kelangan ba buong panel tangalin?
October 26th, 2005 09:41 PM #13
Um, you usually have to take the door panel off prior to fixing it.
Have someone drive vehicle while you are locating for noise source.
For convenience, better have some foam handy.
October 28th, 2005 04:36 PM #15
Originally Posted by OTEP
what kind of foam are we talking about here, and where can i find it?
October 28th, 2005 09:27 PM #16
I used to have an extra matress dito sa bahay. I just cut little foam blocks and sinisingit ko between the control rods (what actually moves behind the door panels) and the inner door itself.
October 29th, 2005 05:47 PM #17
i notice that it may be the handle itself that may be rattling.
kapag hinawakan ko kasi, wala ng ingay.
sa loob pa rin ba ang source nito?
October 29th, 2005 11:10 PM #18
Try mo adjust yung control rod na naka-connect sa kanya. Baka too much slack.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
