Results 1 to 10 of 12
- Jun 2004
- 1,311
September 28th, 2005 08:35 AM #1The threads I'm referring to would be in the engine, not on the plugs themselves.
Can I use a carb cleaner?
The problem is I need to change the spark plugs, all four were fouled and had oil on the threads. The fouling was caused by improper timing, however the oil on the threads may have been caused by improper tightening of the plugs when they were installed. Now I need to clean the threads before I put the new plugs...
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 28th, 2005 10:37 AM #3oil on the plugs is normally caused by worn spark plug oil seals under valvecover.
September 30th, 2005 11:46 AM #4
You need to fix the cause of oil leaking into the cylinders. Not just replace the plugs.
September 30th, 2005 12:37 PM #6
The guys is asking how to clean the threads sa head where the spark plug threads into... not the plugs itself
September 30th, 2005 12:48 PM #7
kuha ka ng basahan...basain mo ng gasolina...ipahid mo sa thread ng makina...do the "pick your nose" manuever
- Jun 2005
- 3,774
September 30th, 2005 02:20 PM #9kerosene gamit ko... get some cotton buds or cotton on a stick, dip it in some kerosene, shake the excess then wipe sa thread ng head.
September 30th, 2005 04:57 PM #10
What engine kaya? kasi parang ang hirap 'i-pick nose' pag malalim di ba? baka dapat gawa ka ng parang cotton buds na mahaba? hehe
Nakakakilabot yung bagong srps taking into consideration na mag-10 years na ang current model neto.
All New Toyota Hilux
