Results 11 to 20 of 21
- May 2005
- 269
August 21st, 2007 08:33 AM #11Depende yan sa AT transmission ng Maufacturer. All 2nd Gen CRV AT has that problem. All of my friends who owns one are complaining, including myself. There's a lag when flooring the accelerator.
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 29th, 2007 10:18 AM #13on older cars with distributors you check the timing on a regular basis. pero kung di naman ginalaw yung distributor ok lang to not touch it.
on newer cars with wasted spark and or coil on plug ignition systems it is the computer that controls the timing and it cannot in most cases be adjusted by the user.
July 25th, 2008 01:43 AM #14
great info guys! parang parehas din kasi kami ng problem sa a32 cefiro. kinakapos sa power tapos pag namatayan ng makina ang hirap istart, e bagong palit lang yung spark plugs. baka minsan mapadaan ako kila sir speedy sabay na din sa royal purple! XD sinusubukan ko ngang i floor yung revolution pero hanggang 4 lang yung abot e... haaay
July 25th, 2008 02:44 AM #15
Plus 1 ito!
Check your tranny fluid. Flush mo na ang tranny fluid pati narin yong filter ay papalitan mo narin dahil barado na yan. Did you know that Transmission is one of the most neglected parts of the car? Most owner are concentrated only on the engine maintenance, but not on the tranny.
As you stated maganda naman ang andar ng kotse mo at pinaayos mo pa, so go other way around.....you dont have nothing to loose.
* Yudyin.......great info guys! parang parehas din kasi kami ng problem sa a32 cefiro. kinakapos sa power tapos pag namatayan ng makina ang hirap istart, e bagong palit lang yung [COLOR=blue! important][COLOR=blue! important]spark [COLOR=blue! important]plugs[/color][/color][/color]. baka minsan mapadaan ako kila sir speedy sabay na din sa royal purple! XD sinusubukan ko ngang i floor yung revolution pero hanggang 4 lang yung abot e... haaay
Check your fuel filter baka clogged lang yan at kinakapos ng gas kaya namamatayan ng makina. Start uli yan kapag bumaba na ang mga dumi na nakabara sa outlet ng fuel filter mo at babara ulit kapag takbo na naman ang gas papunta sa makina. Pa check mo rin ang fuel pump at presuure regulator baka nagloloko na. Kapag malamig ang fuel pump aandar pero kapag uminit na nagloloko parang kapos ang takbo at namamatay at hirap naring aandar hanggang lalamig na naman ang pump.Last edited by v6dreamer; July 25th, 2008 at 03:02 AM.
July 25th, 2008 11:57 AM #16
- Nov 2003
- 3,849
July 27th, 2008 10:04 AM #17have the tranny flushed. it might improve the hatak lalo na if the old fluid is burned na.
August 17th, 2008 10:48 PM #19
isa sa mga important sensor na pinagkukunan ng reference signal ng computer ay ang MAF sensor. MAF sensor ang sumusukat sa volume ng air then the signal it produce will be the reference signal ng computer for air and fuel mixture. pag sira or marumi ang MAF sensor walang power ang engine.
sa automatic transmission naman ang VSS and TP sensor naman ang pinagkukunan ng reference signal ng ECU para sa shifting nya. pag sira yung either sa dalawa, ma eexperience mo yung poor shifting ng gear, minsan delayed minsan naman advance.
mas maganda na pa check mo na yung PCM/ECU kung may present na DTC (Diagnostic Trouble Code). hindi lang consult ang pwede sa mga nissan pwede rin yung ibang scan tool tulad ng carman scan vg, ang disadvantage lang ng carman compare sa consult is hindi nakakapagprogram ng ECU, BCM, and Immobilizer pero pwede naman sa kahit anong sasakyan Asian and American.
September 8th, 2008 07:50 PM #20
Xiaomi E-Car
