Results 1 to 10 of 11
- Sep 2004
- 132
October 10th, 2005 05:11 PM #1masama ba? it affects alignment daw? any other would be problems?
i'm planning to put rubber spacers muna to maintain ride height. temporary solution lang ba 'to?
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 11th, 2005 03:20 AM #4
temporary solution lang yan. baka lumaki pa yun gastos mo sa remedyo.
- Sep 2004
- 132
October 12th, 2005 10:24 AM #5thanks sa replies.
tanung ko lang, anu ba worse na puede mangyari kung hindi agad mapalitan yung coil springs? posible ba maputol yun
October 12th, 2005 03:28 PM #6
how do you know if your coil springs are weak? how do you know if your suspension is bottoming out on bumps?
October 12th, 2005 09:39 PM #7
It depends how bad those springs have sagged, some were down to 50% of their height which should also lessen the amount of load you could load on it. Unless it is overloaded past your original loading weight, it won't snap.
Common signs of weak springs are sagging below normal height, inability to load its intended capacity. Bottoming out on humps or bumps means shock absorber is due for change.
October 13th, 2005 01:20 AM #8
I purchased replacement springs (BCK brand) for my car. They had much thicker coils, so the ground clearance is around 5 fingers with stock wheels, a bit higher than the original. This certainly sags less than before, but the ride was somewhat harder.
- Sep 2004
- 132
October 13th, 2005 10:46 AM #9Originally Posted by orly_andico
in my case the height at the back is lower by almost an inch. tires sometimes hit the fender especially when i pass bumps.
when going slowly on humps, i get this "rear shaking" feeling. for a second lang naman. sa highway naman, parang maalon yung takbo ng auto.
temporarily i have put spacer/lifter.
