Results 11 to 20 of 90
Toyota is my choice
- Aug 2005
- 2,063
June 15th, 2007 11:32 PM #12yep ayos ang wd40 pang cleaning and lubricate. mostly spray ko sya outer ng carb... I also have a carb cleaner para sa inside..
OT: wD40 partner ng tamiya 4wd ko yan nu.on Highschool pa ako
June 15th, 2007 11:45 PM #13
Nakow..........nabuhay ulit, hinalukay sa baul!
Anyways, eh sa disc brakes, ok din ba WD40 pantanggal ng kalawang?Napansin ko kasi medyo may portion na may kalawang yung disc brakes ko.
- Oct 2004
- 278
June 16th, 2007 12:24 AM #14...just be sure you don't spray WD40 to your fan/alternator/timing belts...
as it will shorten their lifespan....
Zombie
- Aug 2006
- 728
June 16th, 2007 12:30 AM #15boss may nabibiling brake cleaner. wag mo gagamitin ang wd-40, baka di kumapit brakes mo
June 16th, 2007 06:49 AM #16
May 24th, 2008 08:34 AM #18
True. Change that cable or?
Before changing on it why dont you try working on just a bit. Your problem have two possibilities...maybe the throttle butterfly shaft is sticking in the throttle chamber, or the throttle cable is binding up. What you can do is disconnect the throttle cable to the throttle shaft and the gas pedal. Then move the cable back in forth to make sure it slides back and forth easily. If not you will have to replace it. If the cable is okey, then you need to give the throttle body a gooooooooood cleaning
August 2nd, 2020 07:24 PM #19
Saw a YouTube video na ginamit yung WD-40 para sa railings ng windows, to "prolong the life of Power Windows" daw
Di ba sya nakaka-sira ng tint?
August 2nd, 2020 07:38 PM #20
Not sure about tint, but it has to be silicone based so it won't damage the rubber seals. Yung regular WD40 spray lubricant petroleum based yun. Meron din silang silicone based lubes.
Edit:
It looks like WD40's silicone sprays also have petroleum distillates in them. So still not safe for plastic/rubber.Last edited by Wh1stl3r; August 2nd, 2020 at 07:52 PM.
https://www.autoindustriya.com/auto-industry-news/nissan-confirms-van-partnership-with-mitsubishi-fo...
Mitsubishi Philippines
