Quote Originally Posted by afrasay View Post
Check the spring in the pedal. Change your accelerator cable. Baka stuck up na yan.
True. Change that cable or?
Before changing on it why dont you try working on just a bit. Your problem have two possibilities...maybe the throttle butterfly shaft is sticking in the throttle chamber, or the throttle cable is binding up. What you can do is disconnect the throttle cable to the throttle shaft and the gas pedal. Then move the cable back in forth to make sure it slides back and forth easily. If not you will have to replace it. If the cable is okey, then you need to give the throttle body a gooooooooood cleaning
