Page 2 of 9 FirstFirst 123456 ... LastLast
Results 11 to 20 of 90
    ok nga itong wd40, dami pakinabang..
    Aug 2005
    yep ayos ang wd40 pang cleaning and lubricate. mostly spray ko sya outer ng carb... I also have a carb cleaner para sa inside..
    OT: wD40 partner ng tamiya 4wd ko yan nu.on Highschool pa ako
    Nakow..........nabuhay ulit, hinalukay sa baul!
    Anyways, eh sa disc brakes, ok din ba WD40 pantanggal ng kalawang?Napansin ko kasi medyo may portion na may kalawang yung disc brakes ko.
    Oct 2004
    ...just be sure you don't spray WD40 to your fan/alternator/timing belts... as it will shorten their lifespan....
    Aug 2006
    boss may nabibiling brake cleaner. wag mo gagamitin ang wd-40, baka di kumapit brakes mo
    hehe kahit luma may pakinabang pa rin..
    Apr 2008
    Guys,
    WD-40 safe ba sa Car Paints?
    May 2007
    Quote Originally Posted by afrasay View Post
    Check the spring in the pedal. Change your accelerator cable. Baka stuck up na yan.
    True. Change that cable or?
    Before changing on it why dont you try working on just a bit. Your problem have two possibilities...maybe the throttle butterfly shaft is sticking in the throttle chamber, or the throttle cable is binding up. What you can do is disconnect the throttle cable to the throttle shaft and the gas pedal. Then move the cable back in forth to make sure it slides back and forth easily. If not you will have to replace it. If the cable is okey, then you need to give the throttle body a gooooooooood cleaning
    Jul 2013
    Saw a YouTube video na ginamit yung WD-40 para sa railings ng windows, to "prolong the life of Power Windows" daw
    Di ba sya nakaka-sira ng tint?
    Not sure about tint, but it has to be silicone based so it won't damage the rubber seals. Yung regular WD40 spray lubricant petroleum based yun. Meron din silang silicone based lubes.
    Edit:
    It looks like WD40's silicone sprays also have petroleum distillates in them. So still not safe for plastic/rubber.
wd 40
