Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Aug 2006
    #21
    If you can find a REdline water wetter that would be great.
    " WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations. "
    Tried and tested.
    #22
    Water wetter is great. But it's quite expensive over here. Probably not worth it for most of us who just drive average joe commuter cars.
    Mar 2005
    #23
    Quote Originally Posted by userfriendly View Post
    Can you mix different brands of coolant but same type or not? Ex caltex mix with prestone. Also if the manual says use dexcool type coolant will it matter if i use a different type say ethyl glycol?
    Mix only compatible types. When in doubt, don't.
    Actually Dexcool also uses ethylene glycol. The difference is the anticorrosives. Dexcool uses OAT, conventional coolants use silicates, etc
    #24
    mga sir, walang sumagot sa tanong ko - san po nilalagay ang Engine Coolant? ano ang kaibahan ng engine coolant sa radiator coolant? thanks a lot!
    Jun 2006
    #25
    Quote Originally Posted by prinsipe View Post
    For top ups, put 50/50 mix of h2o and coolant sa coolant overflow tank. Ito yung plastic tank na malimit nakasult coolant only. Fill until full level only. It will go to the radiator by itself.
    engine coolant and radiator coolant are the same.
    Jul 2006
    #26
    Magkano yung watter wetter dyan? Dito sa US I saw one for $6/bottle sale yata.
    #27
    thanks a lot!
water-coolant ratio??
