Results 1 to 13 of 13
    Jul 2003
    Hello,
    meron po ako 2001 Rav4. may lumalabas na thick white smoke every 1st start and 1st 10 seconds of idle ng engine.
    Parang burned oil ang amoy at makapal na usok.
    Pero after 10 seconds ok na,wala na usok kahit patayin ko pa then start uli after several hours ok na.
    Pero once gamitin ko sya the whole day, ganun nanaman kinabukasan pag start ko uli usok nanaman
    Anyone encountered the same problem?
    Aug 2005
    For gasoline car IMO is normal coz cold start nga po,malamig pa engine and pag uminit na eventually wala na rin yung smoke.Black smoke naman po kasi for diesel if may problem.
    Jul 2003
    Quote Originally Posted by monsrick View Post
    i think you are referring to water vapor. yun din akala ko nung una pero un sakin iba, un parang blow by engine sya pag bumuga parang pugon eh
    Its possible that oil can enter the combustion chamber at starts ups because walang pang heat and pressure to push the piston rings against the cylinder walls. Parang what happens to firecrackers pag suppot. While the engine gets older a tight seal loosens and eventuially leads to blow by. Remember also that cold engine burns richer fuel to attain NOT then leans when it does.
    Dec 2003
    this is just normal for morning start ups for the engine...
    no problem at all..
    * monsricks black smoke for diesel engines are normal too.. wag lang yung bluish white na usok, medyo hindi na maganda yun..
    Nov 2003
    check the pcv... it could be that.
    Jan 2003
    Quote Originally Posted by karlbo View Post
    no problem at all..
    pag blusih white smoke anong ibig sabihin nun?
    Nov 2007
    white smoke = condensate that is accumulated in the exhaust that vaporizes again once hot air flows through. I think this happens because the engine cools slower thus cold air move thru the exhaust system thru convection. During the process, some water vapor is trapped inside the exhaust system and then expelled when the engine is running. Just my opinion
Thick white smoke during cold start?
