Results 1 to 10 of 13
- Jul 2003
- 17
December 3rd, 2007 09:05 PM #1Hello,
meron po ako 2001 Rav4. may lumalabas na thick white smoke every 1st start and 1st 10 seconds of idle ng engine.
Parang burned oil ang amoy at makapal na usok.
Pero after 10 seconds ok na,wala na usok kahit patayin ko pa then start uli after several hours ok na.
Pero once gamitin ko sya the whole day, ganun nanaman kinabukasan pag start ko uli usok nanaman
Anyone encountered the same problem?
December 3rd, 2007 09:12 PM #2
For gasoline car IMO is normal coz cold start nga po,malamig pa engine and pag uminit na eventually wala na rin yung smoke.Black smoke naman po kasi for diesel if may problem.
- Jul 2003
- 17
December 3rd, 2007 09:22 PM #3
December 4th, 2007 01:34 AM #4
Its possible that oil can enter the combustion chamber at starts ups because walang pang heat and pressure to push the piston rings against the cylinder walls. Parang what happens to firecrackers pag suppot. While the engine gets older a tight seal loosens and eventuially leads to blow by. Remember also that cold engine burns richer fuel to attain NOT then leans when it does.
December 4th, 2007 02:02 AM #5
this is just normal for morning start ups for the engine...
no problem at all..
* monsricks black smoke for diesel engines are normal too.. wag lang yung bluish white na usok, medyo hindi na maganda yun..
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Jul 2006
- 145
December 7th, 2007 07:33 AM #7Mga Guru, yung kotse ko GLI bigbody 93 model, ganito naman ang observation ko: Pag start sa umaga, magtutubig ang tambutso tapos white na vapos ang nalabas pero pag medyo mainit na mawawala, as in wala kang makikitang kahit anong usok. Pero pag ni-rev mo yung engine lalabas ang usok kulay blue. habang nirerelease nawawala naman. nangyayari lang pag nirerev ng malakas. Ano po kayang problem nito, di naman po basa ang spark plug. May nagsabi sa akin idrain ko daw yung gas tank then saka mag pa gas ng bago. Please advise po.
December 7th, 2007 07:52 AM #8
- Jul 2003
- 17
December 9th, 2007 11:42 AM #9
- Nov 2003
- 3,849
December 9th, 2007 08:24 PM #10bluish smoke means burning oil. could be a busted valve seal or worse piston rings na busted na.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
