For gasoline car IMO is normal coz cold start nga po,malamig pa engine and pag uminit na eventually wala na rin yung smoke.Black smoke naman po kasi for diesel if may problem.
Its possible that oil can enter the combustion chamber at starts ups because walang pang heat and pressure to push the piston rings against the cylinder walls. Parang what happens to firecrackers pag suppot. While the engine gets older a tight seal loosens and eventuially leads to blow by. Remember also that cold engine burns richer fuel to attain NOT then leans when it does.
this is just normal for morning start ups for the engine...
no problem at all..
* monsricks black smoke for diesel engines are normal too.. wag lang yung bluish white na usok, medyo hindi na maganda yun..
Mga Guru, yung kotse ko GLI bigbody 93 model, ganito naman ang observation ko: Pag start sa umaga, magtutubig ang tambutso tapos white na vapos ang nalabas pero pag medyo mainit na mawawala, as in wala kang makikitang kahit anong usok. Pero pag ni-rev mo yung engine lalabas ang usok kulay blue. habang nirerelease nawawala naman. nangyayari lang pag nirerev ng malakas. Ano po kayang problem nito, di naman po basa ang spark plug. May nagsabi sa akin idrain ko daw yung gas tank then saka mag pa gas ng bago. Please advise po.
Baloney!
Well, not a bad idea also to drain and clean the gas tank to remove water or any other residue that accumilated in time that caused harmful to engine. Anyway, water from the tailpipe is a normal condition. One of the byproducts of the catalytic converter process is, transforming harmful vapors into.....not so harmful vapors. One of those is water vapor, the vapor will condense on the exhaust pipe walls and accumulate inside it. If you notice, there is a hole in the bottom of the muffler to allow the trapped water to escape and it will also drip from your tailpipe once you start your car.
bluish smoke means burning oil. could be a busted valve seal or worse piston rings na busted na.
