Sa akin cold patch pa rin . Depende rin sa Brand ng cold patch iyong germany at mahalaga iyong magkakabit siguraduhing malinis at na scrape na maigi ang pagkakapitan nito kung hindi bibitiw ito sisingaw rin.
Never had a problem with hot patch. Yung pasak + cold patch bumalik yung leak within a month, I think low quality yung ginamit na cold patch. Yung mga hot patch never nagka problem for years. Depende rin siguro sa nagluluto lol.
Pag nasa gitna yung patch.. ok yan cold patch.. pero pag malapit sa side wall mas ok yung hot patch.. pag nag bend kasi yan cold patch bumibitaw..
Pag hot patch dapat temp controlled yung hot plate.. pag nasobrahan kasi masisira yung tire
Ung gulong ng sasakyan namin, every two days ko pinapahanginan sa mga nakalipas na buwan. Napagod nko kaya kahapon, nagpunta ako sa vulcanizing shop. Tatlong screws ang nakadali. Grabe talaga kalsada dito.
last month, i developed a slow leak.
bringing it to the local vulcanizing shop, they found two holes.
magkano?
dalawa po. times 2.
"bossing, isang beses mo lang binaba at ikakabit ang gulong. times 1 na lang, and a hundred more for the extra patch."
heh heh heh.
an observation,
i seem to be getting more flats in my wide tyre, than in my not-wide tyre...
i am seriously thinking of converting it to smaller-diameter-but-taller aspect ratio.
hirap rin kasi mag-visual tantiya kung malambot o hindi, ang wider low aspect tyres...
i just do not know how it will look on the car...
UPDATE FOR MAY 2026
Backstory:
I noticed a clicking noise from my right front passenger tire last night while on E. Rodriguez Ave. When I parked at my relative’s house in New Manila, I found the culprit was a screw wedged almost dead center in the tire. Fortunately, it was not leaking air, and since I wasn’t in the mood to change to the spare tire (tinatamad/pagod na/gabi na), I just decided to drive out and have it vulcanized.
Most of the vulcanizing shops had closed for the night already, but I finally managed to find a 24hr one some 5-6kms away, and they only offered the tire plug (“TUSOK”) method so I had it done. When I got back to spend the night with my relatives, I overinflated the tire to 45 PSI to test if the repair would hold. The following morning (10+ hrs parked in a covered garage so tires were cool already) I checked on the tire and there was no deflation (Good!)
After setting it to the normal cold tire PSI listed on the driver side pilar, I drove out and had it cold patch (“TAPAL”) vulcanized as well.
UPDATED VULCANIZING PRICES FOR MAY 2026 (per hole)
Tire plug “tusok” vulcanizing--------Php 250.
Cold patch “tapal” vulcanizing------Php 300.
Hindi dapat nalalayo ang presyo diyan give or take mga 50-100 pesos. Any other price is mahal, or an outright RIPOFF. Baka nagsasamantala lang yan knowing you need to have the tire patched. There ARE folks like that.
Always have a spare, set at the proper inflation so you won’t be at the mercy of evil people.
On my part, I hyper-inflate my spare (but below max PSI listed on sidewall) because it gradually loses pressure forgotten and neglected in the trunk or back door rack carrier. You can simply deflate to proper pressure later when you need to mount it (in case you don’t have a portable inflator, or discover that it doesn’t work anymore – out of sight, out of mind)
Why am I posting these updated (reasonable) prices – because I see local posts online (Reddit, soc med.) about people being charged P700, P500 etc. per puncture... you are being cheated!!!
TO UPDATE THE OUTDATED/DUBIOUS INFO IN OLD POSTS ON THIS THREAD:
Why did I have my tire double vulcanized? (Asyong aksaya, OC, paranoid?)
No.
The latest industry standards information state that:
-Tire plug “tusok” vulcanizing is only a temporary solution.
-Cold patch “tapal” vulcanizing by itself is not actually 100% satisfactory either.
-”Plantsa” “Luto” hot vulcanizing is destructive to the tire.
Unless you have no options or its a real emergency, better to get dirty and mount your spare so you can drive and look for other shops.
-Punctures on the sidewall CANNOT BE SAFELY REPAIRED. Replace the tire.
Yes, people here in the Phil do that. Pilosopo pa: “Wala naman nangyari ah, I’ve been using the tire for years, thousands of kms. later it’s still fine!”
Bahala ka. Hopefully, when it fails, wala kang madadamay. If it never does, eh di good.
-Punctures on the shoulder of the tire CANNOT BE SAFELY REPAIRED. Replace the tire.
Same comment as above (pilosopo, etc.)
-Punctures over 6mm in diameter CANNOT BE SAFELY REPAIRED. Replace the tire.
Same comment as above.
According to the latest available info, the only acceptable industry standard repair, provided the puncture is in a repairable area) is by using a tire mushroom patch. Basically, its a combination tire plug/cold patch that’s not (usually) available locally. I recall years ago there was a shop that advertised this kind of vulcanizing, but it disappeared. Mahirap na makahanap niyan ngayon, and I’m not in the mood to go searching for one, so I did the best I could with what is available.
I think tama rin yung sequence ng vulcanizing ko. Tusok muna to seal the tread and inner rubber, followed by a cold patch later, to dismount the tire (inspect the interior for damage also) and double seal the tire from within.
THE ADDITIONAL COST WAS ONLY P300. (Why scrimp on such a small amount???)
If the tire still fails later down the road because of the repaired puncture, you can at least honestly say I did the best I could na.
Bakit ba kamo mga PUJ, trucks and other public utility vehicles are rolling around with threadbare, bald or cracked tires (mostly) without incident? Foremost, there is nothing you can do about that, you can only control, and are accountable for your own actions only. Kung gagawa ka ng tama, even if not for the sake of others, then for your own well being man lang sana. I'm always a stickler for wise spending, pero ang maling pagtitipid, masama din.
I only go for the cold patch (aka German patch). This method has never let me down nor have I heard of any significant failures with this method.
What does tend to fail is the pasak/tusok method. While not catastrophic, in my experience these repairs eventually start to leak over time.
Same din with my daily driver, a Vios. I had it vulcanized with the tusok method only at the time.
It’s been seven years, and hasn’t failed/leaked yet- even on trips to Batangas at highway speeds. Wala na rin ako balak ipa-double vulcanize siya (I still know which tire it is, because I keep notes when I rotate them). I also check my vehicle’s tire pressures at least weekly too. Light duty lang naman na siya ngayon, and city driven only na.
I didn’t even replace the tires after 6 yrs, but I will definitely replace them after 10 yrs though (if I keep her pa). Nanghihinayang ako to do so, kasi super kapal pa yung tires- 23,000+ kms odo lang in the 8 years since I drove her home from the dealership.
Now that I know a (bit) better though, I’ll be double vulcanizing na. Like I said, it was just an additional P300...
Well, since it’s already been cold patched, it wouldn’t make sense to poke a hole again to insert a tire plug. Haha!
But I still think its a better practice now to seal the tread and inner rubber via tire plug, then after curing, DOUBLE seal it from the inside with cold patch. (You get to inspect the inside pa if there was structural damage)
Better likelihood of preserving your tire’s speed rating siguro. (Though not for speed yung tire ko na nadale- it was an AT SUV tire)
Again, magkano lang naman yun...
They've said here that tusok method will damage your tire's steel belt- that's because after pulling the object out, they see the shop staff inserting a long T shaped rod in and out a bit before inserting the plug with a needle like object.
Basically, if nadale na ng object na nag puncture sa tire mo ang steel belt (matindi tama), the damage will already have been done. The T-shaped tool is only to clean and prepare the interior channel/puncture to allow the plug to adhere well. It's like a doctor clearing necrotic (dead) tissue and pus from a badly infected wound to allow it to heal properly.
Besides, do NOT underestimate the plies of your tire's construction - they are VERY, VERY STRONG, lalo na yung steel belted ones.
Have you ever cut apart a tire to see it's construction? I've been able to do so because of the trucks we operate, and non-steel belted pa yung mga yung mga sinauna ha? The plies of a tire are densely inter-woven, criss-crossed meshes of material (non-steel belts usually use nylon) to give strength, rigidity and flexibility to the rubber surrounding it. Imagine the construction of a modern, lightweight bullet-proof vest's interwoven layers. It's THAT STRONG. If a foreign object punches through, and even somehow manages to sever a few... "strings", the overall strength of the entire "web" remains very strong- if not, BULOK repeat, BULOK SOBRA YUNG BRAND NG TIRE NA BINIBILI MO sa katitipid, which should not have been purchased at all in the first place!!! That is, provided that the puncture is 6mm or less - kaya nga above 6cm, replace the tire dapat.
Still not convinced? Let me just say that a QUALITY tire (not necessarily the most expensive)... was designed, and constructed to endure the harshest conditions for it's engineered limits:
-It bears the the weight of the vehicle (squashed),
-Takes the burning sun, UV radiation, cold, water, road/soil chemicals, heat from the road, rocks, pebbles, potholes, internal heat from friction rolling on a surface, repeated torsion from flexing...
-designed to roll for thousands of kilometers without issue, all the while constantly being "dribbled" on hard surfaces during it's service life... BUGBOG SARADO sila...
Come to think of it, even as JUNK, almost indestructible sila. Some of our old discarded truck tires in their parking area, have been around for years... meron pa ata dun since I was in my teens. Sometimes may bumibili, cut up to be turned into flowerpots, sometimes they're cut into strips, and laid out on eskinitas as speed bumps... and they're still there!
