Results 11 to 20 of 34
BANNED BANNED BANNED
- 3,790
September 8th, 2003 08:26 AM #11bossing...with your list of upgrades (which I would estimate to run around P200K at least)....wouldn't you "downgrade" your car's resale value in the end???
If I were you...I'll keep it stock....and then save enough money to buy a real sports car.
just my 2 cents.
September 8th, 2003 11:51 AM #12
B16 parang wala ka yatang muffler? meron akong brandnew original Tanabe R Medallion (Racing type)...sa iyo ko muna offer Php 9.5k non negotiable (installation not included)
meron din akong cone type na filter galing sa Integra Type R Php 3.5k non negotiable
September 8th, 2003 02:00 PM #13
B16 : talk to the Honda guys here , mas marami silang experience sa Honda cars .
September 13th, 2003 07:00 AM #14
Guys do u think that set-up will take me to a 14.3sec in 1/4 mile???
September 13th, 2003 02:21 PM #15
hehehe , probably mid to high 13's if well tune at lighten ang interior mo . nag all motor din ako dati , advantage ka sa power to weight ratio na balance .
- Mar 2003
- 91
September 13th, 2003 05:31 PM #16mid 13's using CTR cams,pistons, adj. camgears & some mild headwork?? woah di pwede mangyari un marami gagawin.. specially SiR pa kaha niya.. low 15's high 14's takbo niyan
DSM, using type-R parts sa b16a can give good gains when tuned properly.. kung baga street/race set-up siya.. tsaka y will u suggest a b16b swap?? mag b18cR ka nalng agad. halos same price din sila
- Mar 2003
- 91
September 13th, 2003 05:41 PM #17b16ba-type-rsir, spend at least 100k you can build a naughty street car..
going allmotor.. is very EXPENSIVE tlga. if gusto mo mabiling sa matutulin tlga prepare to spend as if like ure buying a 2nd hand Civic SiR or any other car out there..
September 13th, 2003 09:13 PM #18
dropping a turbo into a Civic SiR would costs around P50K to P100K and would probably have more power too.
September 13th, 2003 11:21 PM #19
thanks guys!!!gus2 ko kasi ung hiyaw ng VTEC * high rpms eh..unti-untiin ko nmn po nde namn po isang bagsakan...pra mas magaan sa bulsa...although naka-experience n ko makasakay s Turbo...iba kasi ung biglang sipa..ng Vtec ehehe...
September 13th, 2003 11:39 PM #20
the power from a turbo engine also depends on the type & size of turbo used. Using a smaller ballbearing turbo, power will be available even at a low 2500rpm.
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
