Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
    Oct 2004
    #31
    Quote Originally Posted by above
    ENGINE:
    - Custom Individual Throttlebodies (Removed Temporarily)
    - Custom Vacuum Cylinder (Removed Temporarily)
    - 3" Magnaflow Wide-open Exhaust with 3" Slant cut Tip
    - 3" CarSound Cat-converter
    - Dynomax 3" Race Bullet Muffler (Used as Resonator)
    - Custom HyTech (HiTech) 304 SS Header
    - PYR Ported Cylinder Head
    - Lightened Intake and Exhaust Valves
    - Hondata Intake Manifold Gasket Set
    - Power Enterprise Timing Belt
    - TODA Racing Spec B Camshafts
    - TODA Racing 2nd Gen Cam Gears
    - TODA Valvesprings
    - Crower Titanium Valve Spring Retainers
    - Custom Valvecover Ventilation System
    - Golden Eagle Mfg. Godzilla Ductile Iron Sleeves
    - Cometic HP NA 85mm Headgasket (Blown)
    - Cometic HP FI 85mm Headgasket (Blown)
    - Cometic non-HP NA 85mm Headgasket (Still holding at 6000 km)
    - ENDYN Wiseco Rollerwave NA Pistons (14.5:1 CR /w Milled Cylinder Head)
    - ENDYN Wiseco High Compression Piston Rings
    - Eagle Forged Steel Connecting Rods
    - ARP 2000 Rod Bolts
    - ARP Head Studs
    - ARP (Custom Specs) Bottom-end Studs
    - Engine Fully Assembled by Graeme Sheehan
    - Bored and Honed to 1980cc
    - Magnafluxed and X-rayed B18C1 Crankshaft
    - Micro-polished and Fully Balanced Crankshaft
    - Custom B20/B18C1 Hybrid Oil Pump (Ported)
    - Complete Engine/Clutch/Flywheel Balancing
    FUEL SYSTEM:
    - RC Engineering 550cc/min Low Impedance Injectors
    - Custom Injector Resistor Pack
    - B&M Fuel Regulator
    - B&M Fuel Pressure Gauge
    - Walbro GSS-317 In-tank Fuel Pump
    - Custom Fuel Rail for ITB (Temporarily Removed)
    IGNITION:
    - MSD 6AL
    - MSD HVC
    - MSD Distributor Cap
    - MSD 8.5mm Ignition Wires
    - MSD Launch Control Module
    - Custom Engine Grounding Kit
    COOLING:
    - Fluidyne 40mm Aluminum Radiator
    - Fluidyne 21 lb Radiator Cap
    - Fluidyne Radiator Fan
    - Fluidyne Condensr Fan
    - Bypassed Thermostat with Restrictor Plate
    - Custom In-cockpit Fan Activation Switch
    DRIVETRAIN:
    - USDM Integra Type-R Transmission with LSD
    - Clutch Masters Stage III Clutch
    - Clutch Masters 8lb CNC Aluminum Flywheel
    - Energy Suspension Motor Mount Inserts
    - Energy Suspension Shifter Stabilizer Bushings
    - Shortened Stock Shifter
    MANAGEMENT/MONITOR::
    - APEXi Power FC Standalone EMS
    - APEXi Power FC Commander Pad
    - J&S Electronics Ultra Safeguard V.1
    - J&S Dual Monitor
    - Autometer Mechanical Oil Pressure Gauge
    - Autometer Dual Gauge Pod
    - Halmeter Wideband O2 Sensor
    - Halmeter Air/Fuel Indicator
    - Canadian Spec ITR Gauge Cluster
    - Tony the Tiger Fine Tuning
    HANDLING/BRAKING:
    - Eibach Sportline
    - Eibach Camber Kit
    - Koni Sport (Yellows)
    - Integra Type-R Rear Swaybar and Bushings
    - BSQ Swaybar Mounting Kit with Reinforcement Plates
    - Prothane Suspension Bushing Set
    - Energy Suspension Rear Trailing Arm Bushing Set
    - SRR Lightweight LCA's
    - Winter: '95 GSR Rims with Pirelli Winters
    - Summer: 15X6.5 JP wheels with Toyo Proxes RA-1
    - PowerSlot FR/RR Brake Rotors
    - Porterfield R4S Carbon Kevlar FR/RR Brake Pads
    - BENEN Rear Strong Bar
    - Mugen One-piece Rear Tower Bar
    - Integra Type-R Front Tower Bar
    - Integra Type-R Trunk Reinforcement Bar
    - Battery Trunk Relocation with Battery Box
    - Moroso Battery Kill Switch
    Damn! Magkano kaya nagastos ng taong yan? Talagang pinakamagastos ung NA route. I remember sa www.sohchonda.com (sorry SOHC lang pero sana u get the point, :-) ) there's this article from a guy doing the 200bhp (turbocharged) with the turbo and fuel pump (walboro 255 ata un) coming from a mitsubishi donor. I think naretain naman nya un VTEC and not disabled it plus its still roadworthy plus super savings. Here's the complete article..
    http://www.sohchonda.com/v-web/bulle...pic.php?t=5046
    Oct 2004
    #32
    Ahahahah 2K3 pa pala tong thread na toh. sus.
    Aug 2004
    #33
    Quote Originally Posted by KALAMPAG
    haha!!! ako rin kala ko ngayon ngayon lang tong thread na to. :D grabe ang mahal pala... kung ako siguro magiipon na lang ako ng pera tapos bili ng sports car talaga. then after ilang years kung may iuupgrade, upgrade ko na lang :D mas mabilis pa...
    Dec 2003
    #34
    Di ko alam yun ah na matagal na pala itong thread na ito..hehe
Upgrades
