Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
    #21
    Originally posted by ghosthunter
    the power from a turbo engine also depends on the type & size of turbo used. Using a smaller ballbearing turbo, power will be available even at a low 2500rpm.
    True , the smaller the snail the better for faster spool , lalo pa if built ang motor mo , kaya mga high boost for a small economy car .
    BUDDYCLUB : di ko alam na almost same price pala yung B16 at B18C5 , maybe yunf B18C1 , a type R is a type R , the pride n joy of HONDA MOTORS . brand new ng B18C5 is almost $7000 .
    #22
    Guys i have a new wish list..can u suggest the brand/s i shud get??
    Engine:
    Camshafts
    Valve Springs
    Valves
    Retainers
    Cam Gears
    V-AFC
    Pistons
    Full Exhaust Kit
    Headers
    Head Gasket
    C.A.I.
    Valve Cover
    Suspension:
    Front Upper Strut Bar
    Rear Lower Strut Bar
    Neuspeed Yellow*
    Brakes:
    Brake Pads
    Brake Rotors
    Interior:
    Racing Harness
    Racing Seats
    Exterior:
    Angel Eyes
    Carbon Fiber Hood
    Lug nuts
    #23
    why not just get a B18 Type-R Integra engine? Might be easier on the wallet.
    #24
    Magkano ba patak ng ITR/CTR Engine ngyun?ksama kabit? ball park figure pls...
    #25
    to be more specific kse, B16B yung ka price ng B18C1. B16A is the 2nd Gen motor and the B16B is from CTR. And the last time I checked, B18C5 aka B18C Spec-R is $4,600.00; K20A is $5,800.00.
    Kung mag F/I si B16 in the future while building his engine, stick with B16 which is far better than B18 for F/I.
    I also agree with ghosthunter, why not get the B18C.
    But like B16ba-type-RSiR said, B16 is lighter than B18 kaya nga gusto nya mag stick sa B16.
    my advice to you B16ba-type-RSiR...
    "Cross the Bridge when you reach the bridge..."
    I have always thought of going ALL-MOTOR as this:
    DIY everything, this is the essence of going all-motor, a real hobbyist who's not asking some shop to do it for you, all-motor is building YOUR OWN PRIDE and JOY.
    Here's an example of a B18C with 219WHP after the following mods. You can use it as your reference for products to get.
    1995 Acura Integra
    Naturally Aspirated 2.0L
    14.5:1 CR
    9200RPM Redline
    ENGINE:
    - Custom Individual Throttlebodies (Removed Temporarily)
    - Custom Vacuum Cylinder (Removed Temporarily)
    - 3" Magnaflow Wide-open Exhaust with 3" Slant cut Tip
    - 3" CarSound Cat-converter
    - Dynomax 3" Race Bullet Muffler (Used as Resonator)
    - Custom HyTech (HiTech) 304 SS Header
    - PYR Ported Cylinder Head
    - Lightened Intake and Exhaust Valves
    - Hondata Intake Manifold Gasket Set
    - Power Enterprise Timing Belt
    - TODA Racing Spec B Camshafts
    - TODA Racing 2nd Gen Cam Gears
    - TODA Valvesprings
    - Crower Titanium Valve Spring Retainers
    - Custom Valvecover Ventilation System
    - Golden Eagle Mfg. Godzilla Ductile Iron Sleeves
    - Cometic HP NA 85mm Headgasket (Blown)
    - Cometic HP FI 85mm Headgasket (Blown)
    - Cometic non-HP NA 85mm Headgasket (Still holding at 6000 km)
    - ENDYN Wiseco Rollerwave NA Pistons (14.5:1 CR /w Milled Cylinder Head)
    - ENDYN Wiseco High Compression Piston Rings
    - Eagle Forged Steel Connecting Rods
    - ARP 2000 Rod Bolts
    - ARP Head Studs
    - ARP (Custom Specs) Bottom-end Studs
    - Engine Fully Assembled by Graeme Sheehan
    - Bored and Honed to 1980cc
    - Magnafluxed and X-rayed B18C1 Crankshaft
    - Micro-polished and Fully Balanced Crankshaft
    - Custom B20/B18C1 Hybrid Oil Pump (Ported)
    - Complete Engine/Clutch/Flywheel Balancing
    FUEL SYSTEM:
    - RC Engineering 550cc/min Low Impedance Injectors
    - Custom Injector Resistor Pack
    - B&M Fuel Regulator
    - B&M Fuel Pressure Gauge
    - Walbro GSS-317 In-tank Fuel Pump
    - Custom Fuel Rail for ITB (Temporarily Removed)
    IGNITION:
    - MSD 6AL
    - MSD HVC
    - MSD Distributor Cap
    - MSD 8.5mm Ignition Wires
    - MSD Launch Control Module
    - Custom Engine Grounding Kit
    COOLING:
    - Fluidyne 40mm Aluminum Radiator
    - Fluidyne 21 lb Radiator Cap
    - Fluidyne Radiator Fan
    - Fluidyne Condensr Fan
    - Bypassed Thermostat with Restrictor Plate
    - Custom In-cockpit Fan Activation Switch
    DRIVETRAIN:
    - USDM Integra Type-R Transmission with LSD
    - Clutch Masters Stage III Clutch
    - Clutch Masters 8lb CNC Aluminum Flywheel
    - Energy Suspension Motor Mount Inserts
    - Energy Suspension Shifter Stabilizer Bushings
    - Shortened Stock Shifter
    MANAGEMENT/MONITOR::
    - APEXi Power FC Standalone EMS
    - APEXi Power FC Commander Pad
    - J&S Electronics Ultra Safeguard V.1
    - J&S Dual Monitor
    - Autometer Mechanical Oil Pressure Gauge
    - Autometer Dual Gauge Pod
    - Halmeter Wideband O2 Sensor
    - Halmeter Air/Fuel Indicator
    - Canadian Spec ITR Gauge Cluster
    - Tony the Tiger Fine Tuning
    HANDLING/BRAKING:
    - Eibach Sportline
    - Eibach Camber Kit
    - Koni Sport (Yellows)
    - Integra Type-R Rear Swaybar and Bushings
    - BSQ Swaybar Mounting Kit with Reinforcement Plates
    - Prothane Suspension Bushing Set
    - Energy Suspension Rear Trailing Arm Bushing Set
    - SRR Lightweight LCA's
    - Winter: '95 GSR Rims with Pirelli Winters
    - Summer: 15X6.5 JP wheels with Toyo Proxes RA-1
    - PowerSlot FR/RR Brake Rotors
    - Porterfield R4S Carbon Kevlar FR/RR Brake Pads
    - BENEN Rear Strong Bar
    - Mugen One-piece Rear Tower Bar
    - Integra Type-R Front Tower Bar
    - Integra Type-R Trunk Reinforcement Bar
    - Battery Trunk Relocation with Battery Box
    - Moroso Battery Kill Switch
    With all the money spent on mods, imagine what he could have. But what can I say, this guy is a real DIY-enthusiast.
    #26
    Brakes:
    AEM Big Break Kit
    or
    Brembo Gran Turismo Kit
    Apr 2005
    #27
    EY you guys, where can I pick up a K20a in Manila??? do you guys know of a place or is this a US forum. I have a couple projects, both with K24 blocks, looking for ITR heads. Anyone can help me out????
    PM me or e-mail at admin*swapcentral.net.
    Thanx
    Oct 2004
    #28
    mapapamahal ka sa labor kung unti unti yun gastos. Baka half or 1/4 of your upgrades goes only to labor
    Dec 2003
    #29
    ENGINE:
    - TODA Valvesprings
    - ARP Head Studs
    FUEL SYSTEM:
    IGNITION:
    - MSD 6AL
    - MSD HVC
    COOLING:
    DRIVETRAIN:
    - J&S Dual Monitor
    HANDLING/BRAKING:
    - Eibach Sportline
    - Eibach Camber Kit
    Ang haba ah..hehe..Merong akong kagrupo nakaB16 siya umabot ng 500k ang ginastos niya..Kung B18 malamang more than 600k-700k yun..Pagnakakakita ako na thread na ganito sasabihin ko na naman sa dad ko bili na tayo na hatchback para makasali na ako sa PRO...
    B16ba-type-RSiR pagnatapos mo yung set up mo sali ka sa team ko..nyahaha..
    Nov 2003
    #30
    here, will try to help you out....
    Quote Originally Posted by B16ba-type-RSiR
    Hi need some help guys..im planning to upgrade my SiR and ive come up with a list ng mga parts na gus2 ko..can anybody give me a ball park figure for each of the parts...pag-iipunan ko kasi eh...thanks in advance!!
    1. SPOON 4-5k2nd hand / NEUSPEED Front Upper Strut Bar 3-4k 2nd hand
    2. SPOON 3-4k 2nd hand / NEUSPEED Lower Rear Strut Bar 2-3k 2nd hand
    **3. SPOON Lug nuts 2.5k (better get volks, mas matibay 4.5k)
    4. JDM B16b Valve Cover 5k+/-
    5. JDM B16b 13-15k 2nd hand / SPOON Camshafts 20k up 2nd hand
    6. JDM B16b/SPOON Valve springs
    7. JDM B16b/SPOON Valve retainers
    **8. EBC 6k+/set bnew / Tanabe 3-4k bnew / Project U Brake pads 3-4k bnew
    9. JDM (recaro seats are 30-40k for a set of 2 2nd hand) /Sparco Racing Seats
    10. JDM B16b Headers (not too good... go aftermarket or 4-1 na b18 )
    **11. APEX-i V-AFC 8-10k 2nd hand
    12. JDM B16b Pistons
    13. SA/Sparco 4 point Racing harness 2,750+/-
    **14.Carbon fiber Hood 18k and up
    **15. Ice Man C.A.I. 7k up for 2nd hand
    **16. AEM or ANY Brake Rotor upgrade… 10-15k per set of rotors bnew
    -you should also include upgrade to the brake lines.
    **SS brake lines are 8-10k for the complete set
    things with ** are available in the shop fyi
Upgrades
