Results 21 to 30 of 34
September 14th, 2003 03:12 PM #21Originally posted by ghosthunter
the power from a turbo engine also depends on the type & size of turbo used. Using a smaller ballbearing turbo, power will be available even at a low 2500rpm.
True , the smaller the snail the better for faster spool , lalo pa if built ang motor mo , kaya mga high boost for a small economy car .
BUDDYCLUB : di ko alam na almost same price pala yung B16 at B18C5 , maybe yunf B18C1 , a type R is a type R , the pride n joy of HONDA MOTORS . brand new ng B18C5 is almost $7000 .
September 19th, 2003 11:11 AM #22
Guys i have a new wish list..can u suggest the brand/s i shud get??
Engine:
Camshafts
Valve Springs
Valves
Retainers
Cam Gears
V-AFC
Pistons
Full Exhaust Kit
Headers
Head Gasket
C.A.I.
Valve Cover
Suspension:
Front Upper Strut Bar
Rear Lower Strut Bar
Neuspeed Yellow*
Brakes:
Brake Pads
Brake Rotors
Interior:
Racing Harness
Racing Seats
Exterior:
Angel Eyes
Carbon Fiber Hood
Lug nuts
September 19th, 2003 10:35 PM #23
why not just get a B18 Type-R Integra engine? Might be easier on the wallet.
October 1st, 2003 06:21 AM #24
Magkano ba patak ng ITR/CTR Engine ngyun?ksama kabit? ball park figure pls...
October 1st, 2003 06:47 AM #25Originally posted by DSM619
Kung mag F/I si B16 in the future while building his engine, stick with B16 which is far better than B18 for F/I.
I also agree with ghosthunter, why not get the B18C.
But like B16ba-type-RSiR said, B16 is lighter than B18 kaya nga gusto nya mag stick sa B16.
my advice to you B16ba-type-RSiR...
"Cross the Bridge when you reach the bridge..."
I have always thought of going ALL-MOTOR as this:
DIY everything, this is the essence of going all-motor, a real hobbyist who's not asking some shop to do it for you, all-motor is building YOUR OWN PRIDE and JOY.
Here's an example of a B18C with 219WHP after the following mods. You can use it as your reference for products to get.
1995 Acura Integra
Naturally Aspirated 2.0L
14.5:1 CR
9200RPM Redline
ENGINE:
- Custom Individual Throttlebodies (Removed Temporarily)
- Custom Vacuum Cylinder (Removed Temporarily)
- 3" Magnaflow Wide-open Exhaust with 3" Slant cut Tip
- 3" CarSound Cat-converter
- Dynomax 3" Race Bullet Muffler (Used as Resonator)
- Custom HyTech (HiTech) 304 SS Header
- PYR Ported Cylinder Head
- Lightened Intake and Exhaust Valves
- Hondata Intake Manifold Gasket Set
- Power Enterprise Timing Belt
- TODA Racing Spec B Camshafts
- TODA Racing 2nd Gen Cam Gears
- TODA Valvesprings
- Crower Titanium Valve Spring Retainers
- Custom Valvecover Ventilation System
- Golden Eagle Mfg. Godzilla Ductile Iron Sleeves
- Cometic HP NA 85mm Headgasket (Blown)
- Cometic HP FI 85mm Headgasket (Blown)
- Cometic non-HP NA 85mm Headgasket (Still holding at 6000 km)
- ENDYN Wiseco Rollerwave NA Pistons (14.5:1 CR /w Milled Cylinder Head)
- ENDYN Wiseco High Compression Piston Rings
- Eagle Forged Steel Connecting Rods
- ARP 2000 Rod Bolts
- ARP Head Studs
- ARP (Custom Specs) Bottom-end Studs
- Engine Fully Assembled by Graeme Sheehan
- Bored and Honed to 1980cc
- Magnafluxed and X-rayed B18C1 Crankshaft
- Micro-polished and Fully Balanced Crankshaft
- Custom B20/B18C1 Hybrid Oil Pump (Ported)
- Complete Engine/Clutch/Flywheel Balancing
FUEL SYSTEM:
- RC Engineering 550cc/min Low Impedance Injectors
- Custom Injector Resistor Pack
- B&M Fuel Regulator
- B&M Fuel Pressure Gauge
- Walbro GSS-317 In-tank Fuel Pump
- Custom Fuel Rail for ITB (Temporarily Removed)
IGNITION:
- MSD 6AL
- MSD HVC
- MSD Distributor Cap
- MSD 8.5mm Ignition Wires
- MSD Launch Control Module
- Custom Engine Grounding Kit
COOLING:
- Fluidyne 40mm Aluminum Radiator
- Fluidyne 21 lb Radiator Cap
- Fluidyne Radiator Fan
- Fluidyne Condensr Fan
- Bypassed Thermostat with Restrictor Plate
- Custom In-cockpit Fan Activation Switch
DRIVETRAIN:
- USDM Integra Type-R Transmission with LSD
- Clutch Masters Stage III Clutch
- Clutch Masters 8lb CNC Aluminum Flywheel
- Energy Suspension Motor Mount Inserts
- Energy Suspension Shifter Stabilizer Bushings
- Shortened Stock Shifter
MANAGEMENT/MONITOR::
- APEXi Power FC Standalone EMS
- APEXi Power FC Commander Pad
- J&S Electronics Ultra Safeguard V.1
- J&S Dual Monitor
- Autometer Mechanical Oil Pressure Gauge
- Autometer Dual Gauge Pod
- Halmeter Wideband O2 Sensor
- Halmeter Air/Fuel Indicator
- Canadian Spec ITR Gauge Cluster
- Tony the Tiger Fine Tuning
HANDLING/BRAKING:
- Eibach Sportline
- Eibach Camber Kit
- Koni Sport (Yellows)
- Integra Type-R Rear Swaybar and Bushings
- BSQ Swaybar Mounting Kit with Reinforcement Plates
- Prothane Suspension Bushing Set
- Energy Suspension Rear Trailing Arm Bushing Set
- SRR Lightweight LCA's
- Winter: '95 GSR Rims with Pirelli Winters
- Summer: 15X6.5 JP wheels with Toyo Proxes RA-1
- PowerSlot FR/RR Brake Rotors
- Porterfield R4S Carbon Kevlar FR/RR Brake Pads
- BENEN Rear Strong Bar
- Mugen One-piece Rear Tower Bar
- Integra Type-R Front Tower Bar
- Integra Type-R Trunk Reinforcement Bar
- Battery Trunk Relocation with Battery Box
- Moroso Battery Kill Switch
November 5th, 2005 02:11 PM #27
EY you guys, where can I pick up a K20a in Manila??? do you guys know of a place or is this a US forum. I have a couple projects, both with K24 blocks, looking for ITR heads. Anyone can help me out????
PM me or e-mail at admin*swapcentral.net.
Thanx
Tsikot Member Rank 4
- Oct 2004
- 2,315
November 5th, 2005 10:51 PM #28mapapamahal ka sa labor kung unti unti yun gastos. Baka half or 1/4 of your upgrades goes only to labor
November 6th, 2005 12:05 PM #29ENGINE:
- TODA Valvesprings
- ARP Head Studs
FUEL SYSTEM:
IGNITION:
- MSD 6AL
- MSD HVC
COOLING:
DRIVETRAIN:
- J&S Dual Monitor
HANDLING/BRAKING:
- Eibach Sportline
- Eibach Camber Kit
B16ba-type-RSiR pagnatapos mo yung set up mo sali ka sa team ko..nyahaha..
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 6th, 2005 03:16 PM #30here, will try to help you out....
Originally Posted by B16ba-type-RSiR
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
