Results 1 to 10 of 20
June 4th, 2016 05:37 AM #1
May thread ba dito pwede mabasa tungkol sa rust proofing and undercoating? more than a year na tsikot ko, ni hindi pa na underwash. Looking to have it undercoated or rustproofed.
June 4th, 2016 06:39 AM #2
Undercoating is not necessary, it's one of those money making schemes of dealers. Better to spend money on something else.
- Aug 2012
- 2,767
June 4th, 2016 07:24 AM #3We have a 2002 Toyota Revo. Never pina-undercoat or rustproof. Solid pa rin ang ilalim.
Sent from my D5833 using Tsikot Forums mobile app
- 54,293
June 4th, 2016 08:34 AM #4most modern cars are already rust-proofed. it is part of the factory painting process. and no aftermarket "rustproofing" can match its effectiveness.
some writers say undercoating (with that black, tar-like stuff) might be useful if you do a lot of off-road driving, where underchassis rocks and stuff is a real problem.
my 2005 car is still rust-free, even as i did not add any aftermarket rust protection.
besides, undercoat is not light. it's like having an extra ('though small-ish) passenger at all times...Last edited by dr. d; June 4th, 2016 at 08:37 AM.
June 4th, 2016 11:56 PM #5
Ganon po ba yun? I have the mindset na baka kase depende sa sasakyan, mas mahal sasakyan, mas maganda pang ilalim or rustproofed til it's end. yung unit ko kase mirage lang, may mga takbo sya na minsan, sumabit yung ilalim, baka kase nascrape yung paint or coating. So Im looking to have it reinforced.
- 54,293
June 5th, 2016 01:51 AM #6
June 5th, 2016 02:59 AM #7
Salamat. Minsan lang nman sumadsad yung ilalim. mga 2 beses lang nmn. Siguro dalhin ko muna sa gas station at pa underwash ko muna. Silipin ko muna kung okay pa.
Follow up question: Roughly when is a car, needs another layer of undercoating or to be rustproofed? Kung marami nman nagsasabi na maganda yung factory default ng sasakyan, gang kelan ba durability nun?
Salamat
June 5th, 2016 03:34 AM #8
Cars today are manufactured with galvanized steel, with a coating of zinc that prevents oxidation and therefore prevents rust. This zinc coating will stay on your car as long as the chassis is intact. So unless you have a terrible accident (in which rust will be the least of your concern), the factory rustproofing is enough to last your car's lifetime.
June 5th, 2016 06:41 AM #9
If you are concerned about corrosion from the scraped under chassis the better option is to coat the area with paraffin. It protects the ferrous surfaces by sealing oxygen off. I personally tested this on steel handsaw blades and left it out in the rain and no visible rusting or staining was evident
June 5th, 2016 07:31 AM #10
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
