Results 21 to 27 of 27
May 24th, 2006 05:12 PM #21
sa palagay ko lang...
yung tubig baha..mahuhugasan ang grease niya. tapos gagaspang ang bearing at duon na mag-start ang uneveness ng function ng bearing.
tama po ba mga tsikoteers??
hula ko lang. hehehe
May 24th, 2006 05:16 PM #22
Originally Posted by baludoy
yung ugong baka nga yung bagong gulong yung naririnig mo since yun lang naman yung nabago. mas matigas ata yung rubber compound na ginamit sa leMans EC 201 kesa sa leMans RV.
- May 2006
- 6
May 24th, 2006 07:02 PM #23Chances are wheel bearing iyan. Ganyan din nangyari sa gulong ko after some time - umuugong pag bumibilis ang takbo ng kotse. They need to be serviced regularly kasi natutuyo ang grease. More frequently and immediately pag lumusong ka sa baha, else mas mahal aabutin. Pa-check mo na lang to be sure.
Pag sealed type iyan, dalhin sa experto dahil kailangan ng special tools iyan (read: hinde lang martilyo). Pag open type yan, pwede na yan kay Juan. The things to remember when having it serviced are:
1. Nilinis ung bearing at case. Hinde lang sinalpakan ulit ng grasa.
2. Use high temp grease. Madalas ginagamit ay regular grease kasi mas mura at ito ang grease na ginagamit sa hinding maselang parte. Kung ito ang ginamit, babalik ka sa kanila in a couple of months
3. Gumamit ng torque wrench at ng tamang torque. Maraming Juan ang di alam ito. Or tatantsahin lang ito. Now, kung araw araw silang nagrerepak ng wheel bearing, ok lang. Pero kung minsan minsan lang, chances are masyadong masikip ang mailalagay nila. Most of the time, they don't know how strong they are. I had to change one wheel drum because some idiot applied too strong a torque putting back the wheel that the thread gave. Guess what, they said its not their fault when I brought the car back.
Sa bwisit ko, ako na lang nag-palit ng drum. In the process, I found out they applied the wrong grease (nagsisimula ng mangulangot iyong grasa), they put too much grease, and they messed up the lock nut. To top it all, hindi pa nilagyan ng silicone sealant iyong drum cover.
I hope this helps.
May 24th, 2006 08:35 PM #24
Thanks, atumali. That was a very informative post.
I just got back from the local underchassis specialist. As it turns out, the replacement of my tires and the emergence of the humming noise were just coincidental.
The mechanic showed me the bearings for the left and right front wheels and they were very worn out. Ang mahal pa ng replacement bearing para sa Sedona dun sa auto supply, buti na lang may extra cash ako na dala.
Anyway, long story short: they put in the new bearings and my ride is now whisper quiet again.
Just some questions: barring exposure to flood waters, how often should the bearings be inspected, serviced or re-greased? Would you guys consider Servitek to be "competent" when it comes to wheel bearing servicing? Do they have the needed special tools and training for the job? I live in the province, so my only choices are gas station, Servitek, Rapide, and the Kia casa in Dagupan.
Edited to add: By the way, my van has logged 137,000-km in 4 years already and this is the first time I've had the wheel bearings replaced. Okay na ba itong mileage na ito o mababa pa sya para mapudpod yung bearings?Last edited by mikey177; May 24th, 2006 at 08:43 PM.
May 25th, 2006 12:24 PM #25
Originally Posted by crossback
May 25th, 2006 12:32 PM #26
kasi open space yan, di naman sealed ang lalagyan ng bearing eh. normally, pag pinasok ng tubig, nawawala yung lubricant nya (o packed grease), nangyayari, kinakalawang. ayun, since may kalawang sya and tuyo ang lubricant, may friction na sya. resulta....sira....
May 27th, 2006 07:46 AM #27
i had a similar problem. lumalakas yung ugong pag bumibilis ang takbo. turned out it was a bearing problem. other culprits might be tire feathering (yung hind ipantay ang pudpod sa gulong). it was an issue on some cars (read on issued sa 2003-04 nissan 350z). you may need to have the balancing checked rin. kung bearing yan, better have it fixed para iwas disgrasya/abala din.
VinFast VF 3
