Results 11 to 20 of 27
October 29th, 2003 01:01 AM #11
yup, goodyear yan. yun stock tires sa lancer(pizza pie) ng sis ko same problem. and its the same with our space gear.. same problem din sa lancer(el) ng officemate ko
- Apr 2003
- 526
October 29th, 2003 02:15 PM #12bago lang gulong ko. ES100s. Pinabalance and align ko din lahat sa goodyear servitek sa may shaw.
Pwede bang di nila naayos yung pagbalance kaya maingay?
October 29th, 2003 04:43 PM #13
tama. baka nga naka Goodyear NCT3 ka. nacheck na rin ba yung toe in?
October 29th, 2003 08:13 PM #14
Unbalanced front tires will cause your steering to vibrate at 80km/h, while unbalanced rear tires can lead to excessive vibrations from the rear portion. :D
- 56
October 30th, 2003 09:51 AM #15try the tire swap first. naging problem ko rin yan but mine is bridgestone. My guess at first is the wheel bearing kasi lagi ako nababaha before kala ko kinalawang na. I brought it to a shell station para ipa-repack. Sabi daw hindi pwede irepack yung lancer pizza kasi close type daw atsaka hindi nila kaya palitan yung bearing kasi they dont have the equipment. Then I brought it to servitek. They found out na hindi pantay yung thread wear sa left front tire ko. So pinalit nila yung spare tire ko ayun nawala totally yung ugong. Nakatipid pa ako. Pero I learned na importante pala mag pa-align at wheel balance palagi.
October 30th, 2003 03:31 PM #16
Kung bearing iyan, umorder na lang kayo kay Ungas. At baka i-deliver pa.
Pero malamang goma iyan. NCT din goma ng Sentra ng kapatid ko. Para siyang All-Terrain tires sa ingay.
May 22nd, 2006 10:29 PM #17
Up ko lang imbes na mag-create ng bagong thread...
Pagka yung ugong ba ay nariring kahit mga 20 kph lang ang takbo ko, at kahit naka-neutral (coasting), at lumalakas yung ugong habang bumibilis yung sasakyan, gulong kaya ang culprit nito o wheel bearing?
The vehicle in question is a 2002 Kia Sedona. I just had all 4 tires replaced from Dunlop LeMans RV to Dunlop EC 201 about two months ago, and I noticed that the ugong first manifested itself sometime AFTER the tire change. Also, the ugong gets louder when I am turning in a curve, whether to the right or left. Since the ugong manifested itself during the summer months, I have doubts if it was a case of my wheels getting recently submerged in flood waters.
Balak ko din naman ipa-check yung bearings sa Servitek pag ngakaroon ng free time pero gusto ko lang magtanong kung may naka-experience na sa inyo ng maingay na Dunlop na gulong. Thanks
May 23rd, 2006 05:27 PM #18
Originally Posted by mikey177
to check if your car has a wheel bearing problem...
jack your car up and shake your wheel towards you. kung medyo may parang alog or gap, baka nga bearing yun.
May 23rd, 2006 07:07 PM #19
Thanks for the advice, happy. I'll see if I can do that wiggle test tomorrow morning.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
