Did you know that car tires usually wear out in about three to four years? By the time they hit five or six years, you should get them checked every year. And once they reach ten years old, it's time for new ones, no matter what.
Since tires wear down over time, regular check-ups are super important to avoid big problems. So, every driver should know the common signs that their tires might need replacing.
Signs you should be looking are:
1. Bulges or blisters on the surface of the tire
2. Tread wear indicator bars are the same height as the tread
3. Air leaks
4. TPMS warnings
5. Car shakes while driving
6. Your tires are more than three years old
7. Changing weather conditions
I learned more about the signs that you should replace your tires ASAP on an article by Triangle Tires.
