Results 11 to 16 of 16
September 5th, 2004 02:34 AM #11
Price/Performance, it would be more worth it to get a Simota...
I was just joking about the 0.01 psi!... the problem is, the fan may actually push positive pressure into the engine at idle, making it FEEL more responsive, but past idle, it will be the vacuum turning the fan, NOT the electric motor... so in effect, the fan will be a DRAG on power at any engine speeds higher than idle.
September 5th, 2004 08:15 AM #12
I dont believe that turbonator thing! Better get the real SUPER CHARGER.
September 6th, 2004 08:24 AM #13
kapag ganyan lang kababa ang pressure aksaya lang. pupuwede kong i mount sa dashboard ko nakatapat sa akin at least ako ang presko.
I prefer ramflow, parang ibudo sya naka tututok sa intake mo. kapag 100km/h ang takbo you get about 3psi with out moving parts.
katulad ng croydon left lights.
September 6th, 2004 11:26 AM #14
let's try an experiment. get an electric fan (yes, your old "bentilador"), put it in front of a cardboard box big enough to cover the fan diamenter. seal off the space between the fan guards and the box with duct tape. now get a 2 meter long transparent plastic hose, fill 3/4 of it with water then connect 1 end to a hole on the box with tape. let the hose hang so that it is in the shape of a "U". that is your U-tube manometer.
now run the fan. take note of the difference in water level in the U-tube. convert that from inches water to psi. (32 ft water = 14.7 psi)
now check the fan from your computer. compare the size with your bentilador and you will get an idea what that little fan can do if tested the same way.
0.0000000000000000000000000000000000000001 psi i think is a near enough estimate for that turbonator!
September 6th, 2004 11:33 AM #15
I think the turbonator doesn't even move. It's supposed to make the incoming air spin by just going through the curved blades. What good would that do? Hehe.
The Turbonator™ is a non-moving vortex generator that goes inside your air intake hose, right after your air filter.
September 6th, 2004 04:54 PM #16Originally posted by the_wildthing
