let's try an experiment. get an electric fan (yes, your old "bentilador"), put it in front of a cardboard box big enough to cover the fan diamenter. seal off the space between the fan guards and the box with duct tape. now get a 2 meter long transparent plastic hose, fill 3/4 of it with water then connect 1 end to a hole on the box with tape. let the hose hang so that it is in the shape of a "U". that is your U-tube manometer.
now run the fan. take note of the difference in water level in the U-tube. convert that from inches water to psi. (32 ft water = 14.7 psi)
now check the fan from your computer. compare the size with your bentilador and you will get an idea what that little fan can do if tested the same way.
0.0000000000000000000000000000000000000001 psi i think is a near enough estimate for that turbonator!
