Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Quote Originally Posted by rion View Post
    it's a water cooled turbo, however, I'm still scratching my head... in townace forums, they said it's not necessary for a 2C-T/3C-T to have a turbo timer because it's water cooled. however, just last week when we cleaned and replace O-rings on a 2c-t turbo, it also has an oil path in the turbo. just like the water path, the oil has in and out paths...
    un nga,e... siguro nga may oil din...ung oil lines ba sa ilalim(not easily visible), pati din ung sa air-intake may oil din dun,e..
    for me,ha, complex ang turbo ng 2c-t,e.. may water and oil lines, pero walang oil cooler...pakabitan ko kaya...
    if ever may makakapost dito ng how to DIY-tap a used turbo timer, it can be helpful, kahit na anong brand, basta layout lang....madali na magtrace sa unit,e...i'll put one din kasi,e..DIY
    #22
    Quote Originally Posted by alwayz_yummy View Post
    that would be great. may turbo timer kasi kami sa bodega we got off from another surplus vehicle...
    Jul 2006
    #23
    bro, "DIY" method ang ginawa ko para ma-install yung turbo timer ko.
    Here's the key... usually turbo timers have 4 wires, namely:
    Red - +12V constant power (regardless of switch position)
    Black - ground
    Orange - tap to ignition on +
    Green/White - tap to accessory
    since gusto ko pag nag switch ako from ON to ACC eh magstart na ang countdown ng turbo timer, naka-join yung Orange & Green/White wires dun sa Ignition On cable.
    on my everest, the OEM wires are color-coded as:
    +12V constant - Black/Green wire
    White - Ignition On
    Pls. refer to pics below.
    HTH
    Jul 2006
    #24
    add ko lang pala ...
    yung ibang turbo timers merong 5 wires ...
    usually yung 4 wires ay parehas sa post ko sa taas,
    at yung 5th wire ay kailangan naman i-tap sa handbrake indicator/switch
    (kc yung mga turbo timers na ganito required na naka handbrake ka muna before mag-function yung countdown timer nya)
    :D
    #25
    galing! thanks JagXtrm.
    I have na the timer with me, but iba pala yung label niya. "ULTM count down timer"
    count down timer and turbo timer are the same right?
    Jul 2006
    #26
    i think parehas lang sila ...
    may pics ka ng count down timer mo? ilan & ano color ng mga cables nya? maybe i can help
    #27
    I don't think I can install this timer right now. my father would not approve. he is not comfortable leaving the engine running
    Pm nalang kita sir JagXtrm if ever I'm installing my own vehicle na. I will be saving this thread for the future.
    anyways, It has 7 wires from the source, then divided into 2 groups, the one group has 4 wires RED/BLUE/BLACKGREEN. while the other YELLOW/GREEN/GRAY
  8. #28
    thanx sir jag! titignan ko pag may time, kabit din ako nito...
    Feb 2006
    #29
    Quote Originally Posted by JagXtrm View Post
    nagpabili ako sa thailand ng turbo timer last July 2006. brand nya is automann. fit na fit cya sa switches ng everest.
    setting nya is 30 secs, 1 minute up to 9 mins.
    since 4x2 lang ang eve ko, ni-remove ko yung 'blank' rightmost switch & dun ko nilagay yung turbo timer (sa 4x4 everest, eto yung RFW switch)
    another pic, pag sa gabi
    OT: yung dimmer switch pinabili ko rin sa thailand & very simple lang ang installation! yung foglamp switch dito ko na lang pinakabit sa casa.
    - JagXtrm
    ay wow naka turbo timer na si Jag, how much ang pagkabili nyan bro? parang orig na kasama sa Eve. kelangan ko na rin yan, naiinis na kasi ako pag hinihintay ko mag idle Trekker ko.
    #30
    swak din ata yung auto mann timer sa fortuner IIRC.
Turbo Timer - What's the Advantage ?
