Results 1 to 17 of 17
    Mar 2007
    mga boss/tsikoters need your help... where can i buy a turbo kit for civic lxi 95??? brand new or second hand??? and how much will it cost me??? tnx more power to tsikot.com...
    Jul 2006
    Sir, first of all, LXi 95? or LX, I think the EK series started 96 and ended y2k. Anyway, You just dont put a turbo kit on a stock engine. IMO, a change engine is more suitable. There lots of honda engines there that can handle a turbo. Cheapest would be a B16 upgrade, if you're running on stock engine (if that is an LXi, it should be a D15b engine). If you have the moolah to burn, get a B16b Type-R or B18c then install a Unichip (w/c may cost at around 10k php if your lucky) then, better change your stock internals. Get a good header, then start shopping for a turbocharger kit. Go to SpeedLab, those people are very good in installing such stuff, you might get a free dyno run too.
    Mar 2007
    tnx boss... i guess i'll take your advice... tnx...
    Nov 2003
    kahit d15 lang. you're currently carburated and mahihirapan ka lang to tune it. get any injected single cam and ok na yan for turboing.
    May 2005
    i have 100k. kasya naba turbo kit, internals, e-management ,tunning para sa SiR ko? 2nd hand parts will do. aim is 250whp
    Aug 2004
    Yup. 100k is enough, provided you can source many of the parts you need surplus or have them locally fabricated for cheap.
    Brand-new engine management is about 30,000 pesos at a good shop, and it'll include installation and dyno-tuning. You can leave that till last (just keep the car on low boost or completely off boost till then) so you can hit two birds with one stone.
    Secondhand engine management can be had for a low price, but you'll still have to pay installation and about 4k - 5k an hour for dyno-tuning... puwede rin street-tuning, though, if you know someone.
    My friend built his entire kit for between 60-80k (with a secondhand turbine and a secondhand emanage-blue), and he's hitting over 200whp. Could be more, but his clutch starts slipping at high rpms. A brand new turbine should only add about 20-25k to that number (you can get them for 30k+, I think).
    Commercial installations start at about 150k pesos, depending on the shop.
    As for hitting 250whp... I know the B16 can handle the boost, but if your target is this high, you might want to budget a little more for some accessories... an oil cooler, an upgraded clutch (say goodbye to your clutch past 200 whp), maybe sleeve the block (you may not need it, but it'll give you some extra security).
    Actually... I'm betting 100k pesos will net you about 200whp. Any more will cost you more money in terms of tuning, manifold design, and possibly a better or new turbine.
    RE: D15B on boost... agree with the others... swap out for an EFi engine first. heck... if you're going to do that, you can swap to a B16 instead of going D15+turbo, and get similar gains with less hassle.
    One interesting combo... stock B20 (CRV motor) + turbo. The B20 costs much much less than a B16... ;)
    Sep 2004
    Don't forget about upgrading your brakes also. Stock brakes cannot handle the power of a 200-250whp turbocharged engine
    May 2005
    i have only 1 car, i want a reliable everyday driven car. i have no time visiting the talyer month. everywhats ok? b16 turbo nalang or palit block to b20 then turbo. hindi naman ako mkikipagdrag. 70% street 30%expressway. need top speed 2
    Quote Originally Posted by onedayoldchick View Post
    Get the B20 and do a moderate boost turbo setup.
    Aug 2004
    Well...
    The top speed of the stock SiR is around 210 km/h or so.
    If that's not enough for you, you can go the full exhaust route (get surplus headers), get engine management (andaming SAFC na available) and maybe a set of secondhand cams. Each job can be done quickly (in a day or so) so you won't have the car off the road for too long. And get some good brake pads. At the end of that, your car should be capable of hitting 220-230 km/h, and you won't have spent more than 50k pesos.
    Any turbo set-up will take a lot of time and tuning. You'll have to schedule a month at least, or up to two or three if it's a complicated custom job (especially if you really want 250 whp).
    Aug 2007
    you could go with the b20 turbo combo, pro i warn you malakas sa gas tong engine na to. if you want something for reliable daily driving, you may want to stick with a normally aspirated engine sir
    i'd go with sir niky's suggestions. yng hatch ng barkada namin was getting 180+ at the wheels from theses mods :
    engine management (sorry sir niky VAFC para sa b16)
    lightened flywheel and clutch from ACT
    an aggressive chip for the ecu(nkalimutan ko na yng brand e, sorry)
    full free flow exhaust (4 into 1 headers with therma wrap tpos scav muffler)
    cold air intake
    the cams, crank and head were blueprinted, balanced and polished(no porting was done though), all valves were also given an angle cut
    a new set of lighter underdrive pulleys
    and you will need to upgrade the brakes din, di kaya ng stock brakes yng power upgrade e
    this should help release your engines' potential, total namin was less than 70k, hati hati p kmi ng tropa nun kse ginawa naming project car yng oto nya. tumagal lng ng konti sa head work and clutch kse yun lng hindi bolt on. the rest we were able to do on our own
    best part was it still drives like a normal car, medyo mas matigas nga lng yng clutch.aim kse nmin was to have a car that can be driven comfortably pro palaban. daily driver din kse nya yng oto e. plus we were still averaging over 10kms per liter sa city driving
    Sep 2004
    50k seems to be an awful lot of money for a top speed difference of only 10 - 20 kmh.
    IMO, better to spend it on a good A/V system for the car, since the TS wouldn't be feeling the 50k mods anyway, given the condition and traffic in Metro roads. Sa NLEX, nanghuhuli, tapos the SLEX is undergoing construction along certain stretches.
    Aug 2004
    A 20 km/h top speed difference is a big thing. As speed increases, wind resistance increases rather dramatically... for an added 10% to your top speed, you may need about 30-40% more power. For 250 km/h, I reckon you'd need about 220 hp or more on the Civic.
    50k is actually cheap.
    If you want a little kick, you can spend as little as 30k for some really crappy crush-bent pipes from header to muffler.
    We've been looking at my cousin's SiR... Ferman of Speedlab suggests a secondhand Type R exhaust as a cheap option... 12k from midpipe to muffler... and it's quieter than many aftermarket systems. Should provide a 5-10 hp kick. Unfortunately, secondhand name-brand headers still cost about 20k. Brand new costs about 30 - 40k, but that's good for 10-15 hp off the bat.
    VAFC na pala? Hehehe... sorrry... but if you're getting engine management, IMHO, you don't need the VAFC anymore... many of the better engine management systems can do the job better, with a 2-D map (throttle position + rpm) versus the per rpm only map of most AFCs (but if the VAFC can do it, already, then it's fine).
    The only issue with the naturally aspirated route is: to make big numbers, you'll have to sacrifice what little low-rpm torque the B16 has in pursuing a freer-breathing system... that's where the B20/B16 "Frankenstein" swap comes in... giving you extra displacement, extra power and tons more torque... but unless your motor was about to conk out and your crank is wobbling like old spaghetti, I wouldn't recommend going to those extremes...
    Jul 2006
    I'm just curious though on why do you need a turbo. If it's an everyday driven car, why upgrade to turbo? Just for top speed? Get a better car say a Civic SiR with it's stock b16a engine. SiRs gives a decent punch, and I agree with somebody who mentioned better breaks. You can reach speeds up to 200km/h+ but how do you stop that if the brakes can't handle it? It'll be dangerous for you and your car too. If you do have budget for your engine, then at least for the brakes and high performance tires w/c are costly. Mind you, your engine's life will be shortened drastically when compared to stock form when boosted due to the high temperature that it shouldn't normally experience. If it's a toy car, a weekend warrior why not? If it's your everyday ride from point A to B, just get a engine that has a higher output and runs on N/A.
    Just my opinion.
    Aug 2007
    "The only issue with the naturally aspirated route is: to make big numbers, you'll have to sacrifice what little low-rpm torque the B16 has in pursuing a freer-breathing system"
    actually ito yng napansin namin. since daily driven yng oto,we eventually changed the headers back into a 4-2-1 design to improve low and mid rpm torque. and dahil we didn't have a lot of resources to use, and we certainly didn't have money for another engine kng magkamali kami, we opted to go with the safest mods that can help improve the engines' reliability and efficiency. except for the freeflow header/muffler, the other mods made a significant improvement on performance and reliability.
    in the end, cguro more than top end power, mas importante mahanap mo yng tamang balance between performance, reliability and user friendliness ng oto
    Aug 2004
    Yup.
    Consider the fact that a well set-up SR20DE can run with a B16A, despite the B16A being 160 hp as stock and the SR20DE being 140 as stock.
    It's because in acceleration, "power under the curve" matters a lot. If two vehicles have the same peak horsepower, yet one has more torque at, say, 4000 rpm (where you usually fall when you upshift), the vehicle with more torque is making more power throughout their rev range.
    I'm chasing the goal of matching a modified B16A in terms of power, but I'm pretty happy with my engine even if I'm still short of that goal... I have a fat wad of torque that gives me great power from 4000 rpm to 6500 rpm.
    Nov 2003
    100k won't buy you pistons and rods with the turbo kit. kulang na kulang yung amount na yun.
turbo kit
