Sir, first of all, LXi 95? or LX, I think the EK series started 96 and ended y2k. Anyway, You just dont put a turbo kit on a stock engine. IMO, a change engine is more suitable. There lots of honda engines there that can handle a turbo. Cheapest would be a B16 upgrade, if you're running on stock engine (if that is an LXi, it should be a D15b engine). If you have the moolah to burn, get a B16b Type-R or B18c then install a Unichip (w/c may cost at around 10k php if your lucky) then, better change your stock internals. Get a good header, then start shopping for a turbocharger kit. Go to SpeedLab, those people are very good in installing such stuff, you might get a free dyno run too.
