Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    I hear a squeaking sound coming from the front suspension while turning in a tight corner... first time that I've encountered that kind of sound.
    It's a high-pitched sound... parang baboy na kinakatay actually. :rofl:
    CV joint siguro sir
    Jul 2006
    Power steering belt squealing at lock? Maybe power steering fluid needs to be replaced or belt is loose, and at full lock or near that the pump cannot function optimally.
    pag naka stop ka bb dinig mo pa rin or only when you are moving?
    baka po maluwag ang belt or basa yung belt.
    Dec 2007
    Quote Originally Posted by mbeige View Post
    x2.
    Try having your power steering vane pump checked, as well---even just as a precautionary measure. If your P/S pump is shot, it'll start leaking P/S fluid, and the decreasing hydraulic pressure will increase your effort in turning the wheel.
    Nov 2003
    yep, probably the belt. or worst case the bearing of the power steering pump.
    Quote Originally Posted by afrasay View Post
    Only when moving... hindi sya audible kapag naka sara ang mga window.
    Thanks for your answer guys... I'll have it checked soon.
    Hmmm... some addt'l info.
    Naririnig ko din sya kahit straight yung daan (and kapag nakabukas lang ung bintana). Mukhang suspension related ito right?
    Pwede ring front wheel hub bearing, nai-stress when turning then later even at straight umingay na rin.
    check mo nga sensors, abs, pad thickness sensor baka may sumasabit sa rotor. also as XTO said yun axle bearings mo.
    Hmmmm... sige boss afrasay. Napansin ko lang ito right after ko magpa reface ng rotor sa SpeedLab.
    Thanks,
    ako nagkarun ng ganyan ingay nun nag palit ako ng all 4 disc rotors....hehehe.
    Nov 2003
    have them check if the pad retaining clips were reinstalled properly. baka gumagasgas lang sila on the rotor. possible din may contact yung backing plate sa rotor.
    Maz,
    Anu na nangyari dito?
    I had it checked again... they checked if everything was installed properly... oks naman. They just cleaned the braking linings - the squeaking sound diminished after the cleaning process (and the stopping power is now adequate).
    The mechanic also rolled the vehicle (while it was in the lifter) with the front tires out... wala kaming marinig na squeaking sound... pero on the road may konti pa din.
    Dapat kasi may load pag niliko yun tires. Need siguro lagyan ng brake paste yun pads. Ganyan din yun W124 ko. Pag nilinis palagyan ko ng brake paste.
    Got it... thanks... pa-check ko na lang ulit siguro kapag nagpa oil change ako next month.
    Argh... it's back! :cry2:
    Gonna have it checked it again... kapag matagal naka park yung vehicle... minimal ung noise... pero kapag matagal nang ginamit and am parking/manuevering... rinig na rinig kapag nakabukas ang bintana. :seeth:
    Quote Originally Posted by mazdamazda View Post
    pre....mukhang humihingi na ata ng kapalit si rav4 mo ah...
Squeaking Sound While Turning in a Tight Corner
