Results 1 to 20 of 32
    Hmmmm... sige boss afrasay. Napansin ko lang ito right after ko magpa reface ng rotor sa SpeedLab.
    Thanks,
    ako nagkarun ng ganyan ingay nun nag palit ako ng all 4 disc rotors....hehehe.
    Nov 2003
    have them check if the pad retaining clips were reinstalled properly. baka gumagasgas lang sila on the rotor. possible din may contact yung backing plate sa rotor.
    Maz,
    Anu na nangyari dito?
    I had it checked again... they checked if everything was installed properly... oks naman. They just cleaned the braking linings - the squeaking sound diminished after the cleaning process (and the stopping power is now adequate).
    The mechanic also rolled the vehicle (while it was in the lifter) with the front tires out... wala kaming marinig na squeaking sound... pero on the road may konti pa din.
    Dapat kasi may load pag niliko yun tires. Need siguro lagyan ng brake paste yun pads. Ganyan din yun W124 ko. Pag nilinis palagyan ko ng brake paste.
    Got it... thanks... pa-check ko na lang ulit siguro kapag nagpa oil change ako next month.
Squeaking Sound While Turning in a Tight Corner
