Results 11 to 14 of 14
November 27th, 2011 10:02 PM #11
^^Hindi ko na maalala sir kase matagal na din yun, pero nakakuha kami noon sa blumentrit mas mura compare sa banawe depende din sa transmission, ano ba transmission mo sir?
November 27th, 2011 10:06 PM #12
November 27th, 2011 11:13 PM #13
yes dapat talaga napalitan. nung time na binaba yun hindi ako present, nung tapos na trabaho saka ko nalaman na hindi ikinabit yung pressure plate kasi mukhang "ok" pa daw. wala na ako nagawa kamot ulo na lang.
i don't think synchros kasi hindi naman maingay. baka maka-source ako ng cable try ko din palitan. sobra dikit kasi sa exh manifold ang shifter cable ng echo baka sa katagalan naluto na. 2001 model
December 12th, 2011 01:44 PM #14
nadale rin! nakuha sa fresh brake fluid and multiple bleed. wala na yung early morning disengage problem ng clutch.
as for the 2nd to 3rd gear shifting problem, ayos pa nga pala pressure plate, hehehe... shifter cable ang culprit! if you check out the 2nz-fe shifter cables, naka-dikit both sa exhaust manifold - protected only by a heat shield. actually, upon visual inspection ok pa. maybe nag-stretch na lang sa katandaan. no more problems with the (semi)new cables. pagkakabit ramdam agad improvement
high idle RPM at engine start
