Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    #21
    In addition, ang mga coolant may difference, mga extended life usually sa aluminum radiators, ang mga "older" coolants sa copper, di sila pwede paghalo otherwise namumuo sa metal surface or nagpropromote ng corrosion.
    Mar 2005
    #22
    Quote Originally Posted by theveed
    Yeah, as I posted earlier:
    Results of industry standard tests of the new Toyota extended-life (PINK) coolant now show a substantial weight loss (corrosion), both in a 50-50 mix and in a 33% coolant mixture (solder corrosion is much greater in this more diluted solution).
    Apparently the new Toyota Coolant (PINK) doesn't adequately protect against solder corrosion on our soldered brass/copper radiators.
    Dec 2002
    #23
    What about "Peak" brand coolant, is this compatible with jap cars? I've used both the concentrate and the pre-mixed one in our cars.
    Aug 2004
    #24
    Quote Originally Posted by Psylocke
    raikonen,
    ha meron pala sa Toyota Cab? Gago talaga yung tao sa parts dept! Sabi nya wala na! Mali pa yung price na sinabi nya, 189 daw!
    yun din una ang binibigay sa akin but i insisted on the RED one... checked my receipt again and it's 198 nga..
    Mar 2005
    #25
    Quote Originally Posted by raikonen
    Nadaan ako sa Pampanga kaya dun nalang ako bumile sa Toyota San Fernando...
    #26
    newer models pala ng toyota like the previa & innova, doesn't require replacement of coolants until 100K kms! and also the spark plugs, 100K kms din daw ang interval.
    Signature
    #27
    eto toyota pink coolant and absolute distilled:
    nung nag-flush ako ng radiator sa 2000 Revo namin last year, after ilang months nabutas radiator hehe.. pwedeng tsamba, pwedeng hindi.. hindi ko talaga alam ang cause..
    Mar 2005
    #28
    Quote Originally Posted by boybi
    AFAIK 2004 and later come pre-filled with the PINK extended-life coolant. The organic acids deplete very slowly and can last up to 5 years.
    Mar 2005
    #29
    Quote Originally Posted by revoGSX
    Hmmm... baka nga yung pink coolant...
    Mar 2005
    #30
    Where do you guys dump your used coolant?
  11. FrankDrebin Guest
    #31
    Hindi ba repackage lang ang mga 'yan from Caltex?
    Mar 2004
    #32
    Psylocke, Raikonen... taga cab pala kayo? san kayo dun? cabanatuan din kasi ako ....
    Aug 2004
    #33
    paano po ang proper way mag flash ng radiator? continuous flow of water ok na ba yun or kailangan pa talaga ng pang flush na solution para ma wash out yung mga dirt sa radiator?
    yung toyota red coolant kailangan pa i-mix sa distilled water with 50-50 ratio? ok lang ba gamitin ito sa 1987 na land cruiser 60 series?
    thanks.
    #34
    oo nga, meron bang pang-flush ng coolant for radiator and engine? paano yung kalawang sa loob ng engine bay?
    ang alam ko lang is i-drain na yung radiator, then fill it up with 50/50 ratio ..
    Mar 2004
    #35
    dun ba sa reservoir "pure coolant" or "coolant mixed with distilled water" ang dapat ilagay?
    Jul 2003
    #36
    2 years na yun sasakyan namin d pa ako nagpapaflush ng coolant wala din namang sinasabi ang service advisor regarding the coolant
    Aug 2004
    #37
    Quote Originally Posted by Zdre_Wulf
    Sa Toyota Cab ko lang nailabas yung Revo ko, mas malapit kasi yun kesa Toyota San Fernando. But i have lots of friends from cab. san ka ba dun?
    Quote Originally Posted by Fulcrum
    50% coolant / 50% distilled water.
    ang gawa ko ay parati ako may baon na mixture in a 1.5 liter plastic bottle...
    Aug 2004
    #38
    Quote Originally Posted by pissword
    sa 1RZ-E engine ng Revo, every 40,000 kms ang replacement ng coolant accdg to the manual...
    Jul 2005
    #39
    red..green..pink? it matters not...the step to remember when switching from one color to another is this. Thoroughly flush the egine to get rid of the old coolant...that's all there is to it. Proper mixture is im****t. Your vehickle's coolant warning system is set for the proper coolant mixture.With the wrong mixture, your engine could get hot but wouldn't get the overheat warning. The engine could catch fire. Use a 50/50 mixture of clean, drinkable water.
    Oct 2005
    #40
    Mga Bro, may tanong lang ako anong pinagkaiba ng toyota pink coolant na deluted at ng toyota Premix long life coolant? Kasi dito sa middle east ganito ang coolant ng toyota? Thank you..
Toyota Red vs Pink Coolant...
