Results 31 to 40 of 40
FrankDrebin Guest
- Mar 2004
- 89
May 6th, 2005 02:13 PM #32Psylocke, Raikonen... taga cab pala kayo? san kayo dun? cabanatuan din kasi ako ....
May 25th, 2005 03:25 PM #33
paano po ang proper way mag flash ng radiator? continuous flow of water ok na ba yun or kailangan pa talaga ng pang flush na solution para ma wash out yung mga dirt sa radiator?
yung toyota red coolant kailangan pa i-mix sa distilled water with 50-50 ratio? ok lang ba gamitin ito sa 1987 na land cruiser 60 series?
thanks.
May 25th, 2005 04:11 PM #34
oo nga, meron bang pang-flush ng coolant for radiator and engine? paano yung kalawang sa loob ng engine bay?
ang alam ko lang is i-drain na yung radiator, then fill it up with 50/50 ratio ..
- Mar 2004
- 98
June 1st, 2005 01:41 AM #35dun ba sa reservoir "pure coolant" or "coolant mixed with distilled water" ang dapat ilagay?
June 1st, 2005 01:55 AM #36
2 years na yun sasakyan namin d pa ako nagpapaflush ng coolant wala din namang sinasabi ang service advisor regarding the coolant
June 1st, 2005 02:00 AM #37Originally Posted by Zdre_Wulf
Originally Posted by Fulcrum
ang gawa ko ay parati ako may baon na mixture in a 1.5 liter plastic bottle...
June 1st, 2005 02:04 AM #38Originally Posted by pissword
- Jul 2005
- 12
August 7th, 2005 05:27 AM #39red..green..pink? it matters not...the step to remember when switching from one color to another is this. Thoroughly flush the egine to get rid of the old coolant...that's all there is to it. Proper mixture is im****t. Your vehickle's coolant warning system is set for the proper coolant mixture.With the wrong mixture, your engine could get hot but wouldn't get the overheat warning. The engine could catch fire. Use a 50/50 mixture of clean, drinkable water.
- Oct 2005
- 74
April 21st, 2008 01:12 AM #40Mga Bro, may tanong lang ako anong pinagkaiba ng toyota pink coolant na deluted at ng toyota Premix long life coolant? Kasi dito sa middle east ganito ang coolant ng toyota? Thank you..
