Results 1 to 10 of 16
- Mar 2004
- 98
- Jan 1970
- 81
March 12th, 2004 01:09 PM #2just get the right one for you engine. the only down side is that you'll have to make sure you reset your ECU everytime you the battery is disconnected since you'll have to teach the ECU to adapt to the plug's characteristics.
- Mar 2004
- 98
March 12th, 2004 01:39 PM #3u know where i can get one? they say its no longer available in the market. tnx
March 12th, 2004 03:57 PM #4
AFAIK, the stock plugs, properly gapped are still the best.
Some peeps who used aftermarket plugs didnt experience much power difference from using new stock plugs and some even had to retard timing to avoid detonation. If its performance that your after, getting headers and an free-flow intake along with advanced timing and high octane fuel on the OEM spec plugs will be a better option.
My .002
- Jan 1970
- 81
March 12th, 2004 04:05 PM #5I beg to disagree. I think better because I never experienced msifires even at redline area. If you examine the plugs, you can tell if the burn is good from the color. Timing? ECU's nowadays can easily adjust to the plug's better characteristics. Most of all, cheaper on the long run. I had mine for 5 years - still good as new
- Mar 2004
- 98
March 12th, 2004 04:10 PM #6Sir Poops, u know where i can get one?
March 12th, 2004 05:22 PM #7
Spark plugs are on a case to case basis..depends on the applied engine really...some gain a lot...some don't.
- Jan 1970
- 81
March 12th, 2004 06:22 PM #8I bought mine near Anonas where they sell Meguiar's but as I said it was 5 years ago for P2,500. Not sure if they still do.
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 13th, 2004 12:27 PM #9i'd stick to stock plugs. for 2500, you can change them regularly enough to last you 5 years din...
this way you are assured that they are in tip top operating condition also.
March 14th, 2004 01:31 AM #10
Ako din stay stock na lang and replace more often.
Ganun din ang paniniwala ko sa air filter that's why I don't use any fancy high tech intake.
At least every 5thou km, bago ang air filter ko.
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
