Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    #21
    Quote Originally Posted by grand kotse View Post
    Guys ano kaya ang problema yung isang gulong ko hindi naman sya flat at matigas naman sya pero ang pressure nya ay 22psi lang. Nilagyan ko sya ng hangin at parang mas matigas pa sya compare sa tatlong tires na lahat 32psi pero ang gauge nya naging 23psi lang ako kaya ang problema don? Thanks
    Sent from my SM-G920F using Tapatalk
    are we talking of identical tire models?
    baka naman, talagang mas matigas ang rubber nung isang tire?
    but yes, as mina above says, replace your pito.
    Sep 2014
    #22
    Quote Originally Posted by mina_nuka View Post
    Replace your valve core or replace the whole tire valve stem
    Mura lang ba yung tire valve at may size ba yun? Thanks
    Sep 2014
    #23
    ^worse case scenario, may problem yung tire.
    Kelan mo sya binili ang gaano na katagal yang problem?
    Sent from Zenfone 3 on Tsikot mobile app
    Mag 3 years na yung car ko at ngayon ko lang napansin ng mag check ako ng tire pressure.
    #24
    150 bucks and above siguro.
    may imported. may mas imported.
    ang alam ko, for automobile tires, isang size lang. anyway, isang tingin lang sa tire shop, ay alam na nila.
    Sep 2014
    #25
    Yup parehong model lang.
    Sep 2014
    #26
    Safe pa bang gamitin yung tire wala namang singaw yung pito.
    #27
    errr... whypo? is there something inherently wrong with your tire?
    from what i understand, the problem may be the pito and not the tire.
    so, yes! safe.
    Sep 2014
    #28
    so, yes! safe.
    I mean puwede pa bang itakbo yung kotse kahit may problema na yung pito baka kasi magka leak pa yung pito kung hindi ko muna sya palitan
    #29
    *grand kotse
    pwede pa itakbo yan ... basta punta ka na lang tire shop asap
    maganda siguro pa-check mo na lahat ng tires mo ... kasi 3 years mong nakaligtaan
    #30
    my concern is, that pito might be causing erroneous readings, resulting in a vastly over-inflated tire. when used on the road, it might weaken the tire's carcass, resulting in the so-called "oblong". when that happens, the tire would be next-to-useless, as it won't be "comfortable to use", if not dangerous.
    why not use the spare tire in the meantime? bring the questionable tire to the tire shop.
    Sep 2014
    #31
    Quote Originally Posted by kinyo View Post
    *grand kotse
    Hindi naman 3 years regular naman akong na che check ng tire pressure at ok naman lahat dati. Ngayon ko lang napansin na may problema sa pito.
    Tanda ko nagpatire rotate ng huling pms kasama yung reserve at yun ang tire na nagkaproblema. Hindi kaya class B ang mga reserve na gulong he he?
    Anyway ibinalik ko na lang sa reserve yung tire at ipa change ko na lang yung pito next week. Thanks guys.
    Jul 2017
    #32
    normal wear and tear ng gulong yan bro
    Mar 2004
    #33
    Use a proper tire pressure gauge to check the tire pressure instead of the tire pressure monitor ...
    Dec 2016
    #34
    Saan po ba makakabili ng proper tire gauge? I live in the provice kasi. Just got my new car and planning to get one.
    #35
    handyman/diy/ace sa mga malls ... meron lagi tire gauge ... kahit yung mumurahin (<P300) lang pwede na, tama reading, ewan lang sa tibay
    Feb 2014
    #36
    those plastic pencil-type are cheap, durable, accurate
    dial-type na cheapo. useless crap
    dial-type na expensive. hit and miss din
    Jun 2012
    #37
    Quote Originally Posted by jeti View Post
    Everytime na magpagas ka, pa check mo sa mga boy doon sa gas station. Bigyan mo ng bente.
    Aug 2012
    #38
    You can buy from shopee or OLX.
    Sent from my ASUS_X00DDA using Tapatalk
    Feb 2012
    #39
    Meron sa Blade, Goodyear ang tatak. Digital tire pressure gauge.
Tire Pressure Question
